Aggressive Wheels and Stretched Tires....Welcome
Old Mar 6, 2011 | 06:46 PM
  #14361
Max-G's Avatar
Max-G
have you considered any other wheels? are you planning on pulling the fenders?
Old Mar 6, 2011 | 06:53 PM
  #14362
DeeSan's Avatar
DeeSan
Originally Posted by gilby_87
Yeah, as soon as I saw pics of this car my mind was set on how i wanted the car to look as it progresses.
I would love to get 19s as i believe they are better on 350s but the wheels minimum size of manufacture is 20" so it didnt leave me with the option.
With the offsets what would you recommend, thats the part I have trouble understanding.
well people are running various offsets. It all depends on what kinda camber degrees you are aiming for and do you prefer the simple flush look or would you prefer a more aggressive stance with the wheels poking out the fenders ? Rolling the fenders is a must, but you can also flare/pull the **** out of them and fit something more aggressive.
most ppl run setups like Front 19x10 (0 to -10) Rear 19x11/12 (0 to -5)
some setups are even more crazy... but I think there's a limit to what looks awesome. Basically, the lower you go with offsets = more lip, pushing the face deeper into the wheel, however remember that you are also pushing the wheels further outside the car!
Depending on the setup you'll go with, you might also need to purchase camber and toe arms to get back in spec after dropping the car.
You should check out WEDS http://www.weds.co.jp/products/index.html#kranze
They just might have something pretty similar in 19's
Old Mar 6, 2011 | 07:12 PM
  #14363
gilby_87's Avatar
gilby_87
most ppl run setups like Front 19x9.5/10 (0 to -10) Rear 19x11/12 (0 to -5)
I'm aiming for the aggressive stance and would definatley prefer the wheels to have camber, I would like the top of the wheel to be pretty flush with the fender but as it gets lower it angles out slowly, not too crazy like some of the setups I have seen on this page as the car is a daily driven car.
I would like the back wheels to have a lower offset so it can have more lip then the front.
So an offset of 0 to -10 would be suitable for the effect on the front, and 0 to -5 for the rears?
I guess if its not the desired effect I can always get spacers :P
Thanks for all the helpful info, I have searched WEDS and have actually sent them an email regarding a style of wheel.
Old Mar 6, 2011 | 07:27 PM
  #14364
DeeSan's Avatar
DeeSan
With the offsets I gave you, you definitely won't need spacers! Another thing you need to consider is the brake kit you have... do you have brembos (any other BBK) or the base brakes ? Because this will affect the disk type you will have to go with when buying the wheels! Front you should go with mid/regular disk (if you have BBK you should get hi-disk for more brake clearance). Usually you wanna go with low disk in the back for maximum lip. With the numbers I posted you should get front lips around 4.5 inch and 6 inch out back
Old Mar 6, 2011 | 07:30 PM
  #14365
gilby_87's Avatar
gilby_87
Im looking into some wheels by WEDs at the moment aswell.
I dont mind pulling the fenders if its a must do to get the stance I'm after.
Old Mar 6, 2011 | 07:36 PM
  #14366
gilby_87's Avatar
gilby_87
I have the track model which has the Brembo brakes.
That sounds like the amount I think would be ideal, I will do abit more researching before I jump into the deep end and start ordering but thanks for all the help!
Old Mar 6, 2011 | 08:08 PM
  #14367
Royal_T's Avatar
Royal_T
No, No, No, and Hell No. If I see anyone rocking damn Asanti wheels in this thread, I'm out.. Those wheels do not belong on a Z period And don't place a 9.5 up front you will need spacers. Go with 10s in the front for sure. In my opinion the best spec for 19s where 19x10 0 offset and 19x11 0 offset.. It looked the best with not as much pull.
Again this is just my opinion, you can do what ever you want but trust me those wheels do not belong on a Z.
Old Mar 6, 2011 | 09:18 PM
  #14368
darkzschneider's Avatar
darkzschneider
No more picts of my car until my wheels come.
Old Mar 7, 2011 | 12:08 AM
  #14369
4DGS's Avatar
4DGS
^ sick
Old Mar 7, 2011 | 12:16 AM
  #14370
KingBaby's Avatar
KingBaby
Hardest Setting
Throw some Ds on that hoe....
That made my day Royal T...
Old Mar 7, 2011 | 04:04 AM
  #14371
lixam's Avatar
lixam
great....now weds are "bling" and can be emmulated by other "chrome" wheels to achieve the same look as long as theyre blingin like the jdm wheels and proper size/spaced....
as the scene gets more watered down the easier itll be easier to distinguish quality
Old Mar 7, 2011 | 07:42 AM
  #14372
350z_Boi's Avatar
350z_Boi
LMAO.. This made my day!!! Whatever boss man says here. Is right! LOL
Old Mar 7, 2011 | 07:48 AM
  #14373
350z_Boi's Avatar
350z_Boi
@gilby: if you decide to go with a 9.5 front and a 10.5 rear I would go with a -11 all around. For sure you'll just have to roll them fender because that's what we did with my friend's Z and he got to keep his fender liners intact. With just a slight roll and his wheels were also weds but it was the bazrieas like E's old rims but it was all chrome.
Old Mar 7, 2011 | 08:27 AM
  #14374
SpoolageDropout's Avatar
SpoolageDropout
I think I might just go with this size and offset with some DPE'S ,because I cant go to hard living in Maryland these roads suck like ****
19x10 front
19x10.5 rear all with +0 offset
"Might lower the car about a 1.5in just until everything settles"
Old Mar 7, 2011 | 08:41 AM
  #14375
GenX350z's Avatar
GenX350z
My photoshoot with JOHN JILES...
http://www.johnjiles.com/?p=201
Old Mar 7, 2011 | 09:06 AM
  #14376
350z_Boi's Avatar
350z_Boi
19x10 front
rears aren't going to be flush. Go with a 11. Btw how blackhawk project? Still waiting. Lol jk can't wait!
Old Mar 7, 2011 | 09:23 AM
  #14377
iLLest_Z's Avatar
iLLest_Z
will a 265/40 fit a 18X13
Old Mar 7, 2011 | 09:50 AM
  #14378
KingBaby's Avatar
KingBaby
Hardest Setting
Wallpaper right there...
Railroad track pic is a keeper
Old Mar 7, 2011 | 10:06 AM
  #14379
350z_Boi's Avatar
350z_Boi
loving your Z Andy.. Straight up sickness!!
Old Mar 7, 2011 | 11:38 AM
  #14380
Royal_T's Avatar
Royal_T
Love those pics Andy.. very nice.
