Question about same size tires on different width rims.
Old Dec 3, 2007 | 05:58 PM
NiSmoZzZz's Avatar
NiSmoZzZz
Default Question about same size tires on different width rims.
I recently ordered myself some Blizzaks WS-50 at 225/50/17 all around for my stock 17 inch rims I got laying around. Tire Rack emailed me saying they won't fit the rears, but I assumed they could. Can the 225/50 fit all around on the stock 17 inch rims? (I forgot the width of the fronts and rears).
Old Dec 3, 2007 | 06:36 PM
NiSmoZzZz's Avatar
NiSmoZzZz
moved to tire section.
Old Dec 3, 2007 | 06:38 PM
350Z Tire Sizing
Standard 17":
F-225/50WR17
R-235/50WR17
The Tire Rack will try to sell you the OEM size to avoid returns. Of course a 225 mm tire will work on a 7.5 inch wheel.
Old Dec 3, 2007 | 06:43 PM
NiSmoZzZz's Avatar
NiSmoZzZz
Originally Posted by davidv
350Z Tire Sizing
Standard 17":
F-225/50WR17
R-235/50WR17
That's what I thought. So the rear is a 7.5? I thought it was 8.
Old Dec 3, 2007 | 06:48 PM
350Z Wheels
Standard 17":
Alum Alloy
F-17x7.5
23.259lbs
R-17x8
24.140lbs
My mistake.
EDIT. As a general rule, OEM width plus or minus 10 mm is very conservative.
Old Dec 3, 2007 | 06:50 PM
NiSmoZzZz's Avatar
NiSmoZzZz
Will it be a problem or should I be good?
Old Dec 3, 2007 | 06:58 PM
Spike100's Avatar
Spike100
^^ The rear is 17x8", but that is no problem when mounting 225's.
Your stock rims are:
17x7.5” Front
17x8.0” Rear
225/50-17” fit perfectly on these rims (either width… 7.5” or 8” width)
You’re “good to go.” This is a good winter tire setup since you can rotate those studless winter tires that wear quickly when run on a dry surface.
And… If your car has TCS or VDC, you won’t experience any problem running all square 225/50-17” snows.
--Spike
DarkCreep
Oct 17, 2015 11:50 PM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
