Enkei RPF1s - Opinions
Old Dec 12, 2007 | 01:03 PM
DustinZ33's Avatar
DustinZ33
Originally Posted by Z1 Performance
there is no such thing as hard and fast rules when it comes to width, offset and tire size on offsets that low and widths that wide unfortunately, because ever tire is different. Some tires might still rub, some won't - only way to know 100% for sure, is to try it
true. tires vary. I need to take a pic of my rear set up closely so I can see how much clearance I have. Just to do it.
Old Dec 12, 2007 | 01:50 PM
tougeracing's Avatar
tougeracing
forget it man theyre 17s. itll look small on a Z
Old Dec 12, 2007 | 01:53 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the OP said he is doing these as track wheels
Old Dec 12, 2007 | 01:57 PM
Originally Posted by davidv
When you compare the current wheels to the new wheels using an offset calculator what do you get?
Never mind just wing it.
Old Dec 12, 2007 | 02:51 PM
terrasmak's Avatar
this is 17x9 +22 front and +17 rear. 275/40 with 255/40 front. To run 275/40 fronts i'll probably have to pull the 5mm spacer off the front.
Old Dec 12, 2007 | 03:04 PM
intoxicatedpete's Avatar
intoxicatedpete
Looks great.
I think i'm going to go with RPF1 17x9.5 +18 with 255/40's all around.
Z1, I'll go to you when I'm ready to buy. Thanks.
Old Dec 12, 2007 | 05:03 PM
DustinZ33's Avatar
DustinZ33
sounds good to me.
Old Dec 12, 2007 | 05:55 PM
terrasmak's Avatar
Originally Posted by intoxicatedpete
Looks great.
much better off with the 255/275 stagger or 275's all around.
Old Dec 12, 2007 | 08:34 PM
johnlotusboy's Avatar
johnlotusboy
If the 17's fit over your brakes, run the 17x9+35front with 5mm spacers. It is very important to keep the +30 of the Z cars suspension design. If you run the incorrect offset your Steering Axis Inclination (SAI) will be off.
What does this do? Well it will make your car "tram line" pull on the more rutted freeways. The "nervous" feeling that a lot of people have with their lowered 350Z's is just one issue. I ran with 17x9+35 fronts, a 5mm spacer was added 3 months later , stock ease of drive came back with spacer.
Talk to a serious Miata road racer and they will tell you a over 3mm off of stock and the car drives bad.
My current set up is RPF-1's 17x9+35f w/275/40 and 17x9-1/2+38 w/285/40. No clearance issues,.
I like my car to handle and "stupid" light wheels make the car much quicker on the throttle and the late braking gains will have you buddies disappearing in the mirrors. I suggest a JUN chromoly flywheel for even more fun.
Very light weight wheels need a harder brake pad to raise the operating pressure @ abs engagement point, this raises the frequency of oscillation of the solenoids= more responsive and effective abs.
There are other facets to road racing a 350Z, if you would like to have questions discuss in PM's.
Old Dec 13, 2007 | 06:44 AM
DustinZ33's Avatar
DustinZ33
I run 18x10.5 +15 all around and my car feels perfectly fine on more rutted freeways. Actually less pull either way than the stock set up.
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
wanderingstuden
Jan 28, 2016 07:03 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
