Note to self: Don't use Fix a Flat in Winter!
Old Dec 17, 2007 | 11:12 AM
phreaktor's Avatar
phreaktor
Design Engineer
Default Note to self: Don't use Fix a Flat in Winter!
Came out of work, had a flat in a 255/35/20, used Fix-a-Flat to get to the gas station. Pumped up tire, now it feels out of balance with harsh shuddering at about 45-60 MPH.
My guess is that the Fix-a-Flat froze and is basically a big block of ice in my rim? Although it was very cold, it wasn't even freezing weather.
Old Dec 17, 2007 | 11:35 AM
NickRaine78's Avatar
NickRaine78
Fix a Flat is junk to begin with. Plus it pisses off the guys at the tire center who have to clean it.
Old Dec 17, 2007 | 11:36 AM
350z2go's Avatar
350z2go
^^^ haha never thought of that but u right i never use it tho
Old Dec 17, 2007 | 11:45 AM
Yes we know about fix-a-flat. Essentially you just filled a tire with glue. It may be a little difficult to get off the wheel.
Old Dec 17, 2007 | 11:53 AM
phreaktor's Avatar
phreaktor
Design Engineer
They're definitely the first thing I think about when I catch a flat in 37 degree weather.
Old Dec 17, 2007 | 11:54 AM
350z2go's Avatar
350z2go
haha
Old Dec 17, 2007 | 12:27 PM
NickRaine78
I'm thinking donut and a trailer.
Old Dec 17, 2007 | 12:43 PM
sry110's Avatar
sry110
Thanks for the tip. I have never used the stuff and now I probably never will.
Old Dec 17, 2007 | 01:07 PM
SuperBlack350z's Avatar
SuperBlack350z
good thing you don't have expensive rims. Fix a flat are more for steelies IMO. They can mess up wheels pretty easy.
Old Dec 17, 2007 | 02:30 PM
Sean's Avatar
Sean
they mess up TPS sensors don't they.
Old Dec 17, 2007 | 02:31 PM
SuperBlack350z
yes.
Old Dec 17, 2007 | 04:18 PM
Just the one that you filled with glue.
Old Dec 17, 2007 | 06:30 PM
crg914's Avatar
crg914
Note to self: Don't use Fix-A-Flat if you don't want to buy new TPMS sensors!
Old Dec 17, 2007 | 09:49 PM
aloh's Avatar
aloh
dont cut them up either like this!
https://my350z.com/forum/wheels-and-tires/321765-cutting-off-tpms-valve-stems-fail.html
Old Dec 17, 2007 | 10:52 PM
350ZTheStandard's Avatar
350ZTheStandard
Note to self,
*** fix a flat is $hit and NiSSan does not recommend use
*** makes 1 hell of a mess
*** great for killing TPS, next time your at the stealership just price these bad boys
****when the weather gets cold same as when the weather is warm change the damn tire and then directly to a reputable tire shop the have the tire fixed and remounted
*** what were you thinking???
Old Dec 19, 2007 | 05:00 AM
phreaktor's Avatar
phreaktor
Design Engineer
***Nissan doesn't recommend that you install coilovers, but you did that didn't you?
***The mess is inside the tire?
***Don't have TPS
***Already took it off and the tire is shot. It wasn't the Fix-a-Flat. It was the inside of the tire being bubbled from riding on it.
***I was thinking that I was freezing my ***** off and I wanted to get to the gas station down the street.
Old Dec 19, 2007 | 05:04 AM
reptile718's Avatar
reptile718
Please don't ever use fix a flat, it coats the inside of your rim with a nice pile of crap that is a bish to remove. Not only that but when it dries it screws up the balance on the wheel so it will start to vibrate. Its truly just in case of an emergency only type thing.
Old Dec 19, 2007 | 09:39 PM
350ZTheStandard
***Nissan doesn't recommend that you install coilovers, but you did that didn't you? HELL MY LOCAL NISSAN STEALERSHIP SELLS Nismo COILOVERS. SO I GUESS THE WANT YOU TO PURCHASE AND USE EM IF YOU HAVE THE NEED & THE $$$$
***The mess is inside the tire? GUESS YOU DID NOT NOTICE THIS STICKY GLUE CRAP ALL OVER THE WHEEL ON THE INSIDE
***Don't have TPS BASE MODEL???
So you were cold & tired!!! IF SOMETIME YOU ARE COLD AND TIRED AND HAVE TO TAKE A DUMP, WHAT THE HELL, DO THE PAPERWORK LATER WHEN YOU ARE WARM & WELL RESTED.
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
Depravity
Oct 1, 2015 04:49 PM
