Unofficial Enkei Wheels Thread
Old Apr 5, 2015 | 04:31 PM
  #2341
mr. sparco's Avatar
mr. sparco
Is the fender wrapped?
Old Apr 5, 2015 | 09:04 PM
  #2342
terrasmak's Avatar
Originally Posted by NA&CH
Back to enkeis... for track days
Chris
Dam that fender came out perfect. Custom made or is someone making them now?
Old Apr 6, 2015 | 06:14 AM
  #2343
OAKOSAutomotive's Avatar
OAKOSAutomotive
Vendor - Former Vendor
Chris
Nice!
Old Apr 8, 2015 | 03:57 PM
  #2344
NA&CH's Avatar
NA&CH
Yes. It will be wrapped one color soon.
It was custom made. I beleive a company is coming out with one?? Not sure though.
Originally Posted by OAKOSAutomotive
Nice!
Thank you.
Chris
Old Apr 11, 2015 | 06:10 AM
  #2345
NA&CH's Avatar
NA&CH
Battle ready...
Chris
Old Apr 12, 2015 | 07:36 AM
  #2346
Canada_Z's Avatar
Canada_Z
Old Apr 12, 2015 | 02:31 PM
  #2347
Chi-TownWarrior's Avatar
Chi-TownWarrior
For those wondering if Wilwoods fit
18x9.5/10.5
Old Apr 13, 2015 | 10:38 AM
  #2348
prickleypeet's Avatar
prickleypeet
Been reading a lot of responses here and in the Aggressive wheel & Fat Tire thread but just want some confirmation before finalizing what I'm going to buy. Going with the RPF1's 18/9.5 +15 (front) and 18/10.5 +15 (rear). Car was just lowered on Tein S-Tech springs last weekend. No further suspension work will be done (outside of new shocks/struts) unless I need a camber kit after I get an alignment.
I don't mind rolling the rear fenders but would like to avoid any fender work up front if possible. Looking at either 265/35-18 or 275/35-18 tires up front and 295/35-18 tires in the rear.
Which tire size is preferable to avoid rubbing in the front and will that size in the rear with a fender roll, avoid rubbing? If I'm way off base here on what I need please correct me. I don't track it so this is purely for aesthetic reasons. Thanks
Old Apr 13, 2015 | 04:23 PM
  #2349
Z1NONLY's Avatar
Z1NONLY
Fender rolling will be needed in the back for sure. 285/35-18 on 10.5 +15 with -2.5 camber is a tight fit with my rear fenders rolled.
I run -2.75 camber up front and think the 275/35's I ran (also on 10.5 +15) didn't even need the fenders rolled (although I did it anyway). 285/35 is snug though.
Old Apr 13, 2015 | 04:48 PM
  #2350
Chi-TownWarrior
I run a 275/35, - 2.4 camber front and a 275/40 - 2.0 camber rear. I at one point had a 295/35 - 2.5 all around, and didn't like the feel, but you have to roll the rear fenders.
Old Apr 13, 2015 | 10:24 PM
  #2351
terrasmak's Avatar
265/35-18 front and 285/35-18 rear is what I recomend. You will need a roll put back and maybe an ever so slight pull up front ( by hand, just grab and pull, takes 2 minutes per side.)
Old Apr 14, 2015 | 05:36 AM
  #2352
prickleypeet
Thank you everyone, for the replies!
It sounds like 265/35 up front and 285/35 in the rear is the way to go to avoid issues.
Just out of curiosity and I realize everyone's suspension setups and cars are different but people that are running RPF1's (with a +15 offset) with the really wide rear tire setups (295 mm, 305 mm etc); how are they doing this? Is it just messing with the camber of the car? I have a slight drop on my car and it seems that it's prohibiting a tire wider than 285 mm. I guess I'm just a little confused since it seems most people are dropping the car an inch or more and they're able to fit wider tires both in front and in the rear.
Thanks
Old Apr 14, 2015 | 11:57 AM
  #2353
pyshin's Avatar
pyshin
^^^ They are pulling the sh*t out of their fenders, I've also seen the fenders themselves trimmed to make 285+ to fit (or honestly they're just not low). I ran 285/35 on 18x10.5 +15 square for a while, was dropped low with -3.3 f and -2.6 r camber.. still rubbed at full lock on hard driving depending on my dampening. Back to 275/35 f and 275/40 r now.
This is how my front looked right after I installed 285/35 RS3's, before I pulled my front fenders and ran more camber:
Old Apr 14, 2015 | 09:04 PM
  #2354
terrasmak's Avatar
I'm dropped about 1.5 inch in the rear and run -2.2 camber and a 5mm spacer. I can get a 295 on it no problem. The front, 285 is tight , really tight but works.
Old Apr 15, 2015 | 09:44 AM
  #2355
JKoobir's Avatar
JKoobir
just got these got these 2 weeks ago
Old Apr 15, 2015 | 01:21 PM
  #2356
prickleypeet
Thanks for the insight and responses guys. Decided to go with 265/35-18 up front and 285/35-18 in the rear just to be safe this time around (with rolled rear panels).
Old Apr 15, 2015 | 03:10 PM
  #2357
drvqz33's Avatar
drvqz33
Looks perfect!
Old Apr 15, 2015 | 05:04 PM
  #2358
mr. sparco's Avatar
mr. sparco
Looks great on the Mo.
Old Apr 17, 2015 | 04:24 PM
  #2359
NA&CH's Avatar
NA&CH
Love me a white nismo. Looks great.
Chris
Old Apr 22, 2015 | 09:57 PM
  #2360
Jaaarin's Avatar
Jaaarin
Default Rpf1 Fitment w/Brembos
Okay so I tried researching but I couldn't find what I was looking for. So those that are running Enkei Rpf1 with brembos, what are your specs? If you guys have pictures might as well post them too
