Unofficial Enkei Wheels Thread
Old Oct 24, 2021 | 04:59 AM
  #2841
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by travlee
18x9.5 will fit 9n the front. I did a 255/40 and 275/40 tire combo
This^^ is the go-to setup. 18x9.5 and 10.5 +15 (both F&R). Or 9.5 squared WHEELS (tires staggered if you have VDC) works as well. Note: if you lower it, you may need to roll the rear guards. If you prefer not to do this, go with wheels in the +22 and up range.
Old Oct 24, 2021 | 10:12 AM
  #2842
Therealbond's Avatar
Therealbond
so 245 and 265 I should go for 18x9.5 only options are +15 and +30 they’re both concave. I read a lot of places saying it’s stretched on 245 and have read a lot saying it doesn’t
Old Oct 24, 2021 | 11:20 AM
  #2843
travlee's Avatar
travlee
Master
Did you not read? 255/40 & 275/40. Will give you a square shoulder. If you you want to look retarded, get the 30 offset, if you want it to look proper, get the 15 offset
Old Oct 24, 2021 | 12:39 PM
  #2844
Therealbond
let me rephrase. I have 265 245 want to know if 18x9.5 will fit properly on the 245 without it being stretched. I have read that it should fit. And also if I go this route 15 offset on all 4?
Old Oct 24, 2021 | 12:48 PM
  #2845
travlee's Avatar
travlee
Master
Yes on all corners....if you go 245 you will have a more rounded shoulder, if you go 255 it will be squared up
Old Oct 24, 2021 | 12:49 PM
  #2846
travlee's Avatar
travlee
Master
If you already have the tires, run em until they are dead
Old Oct 24, 2021 | 03:08 PM
  #2847
MicVelo's Avatar
245s on 9.5s are fine. A 9.5” wheel is 241mm so a 245 tire is an almost straight up fit. As travlee said, 255s are more squared up but the difference in performance is negigible.
Old Mar 18, 2023 | 07:29 AM
  #2848
ORNG350's Avatar
ORNG350
New to membership, lurking for years. Really like the TS-5 18x8.5/18x9.5 wheels and see that they are all +38 offset.. I have the minimal drop lowering springs- under 1" or right near. Can't recall brand at the moment. Anyways, been searching for hours on offset calculators and so on. Can anyone guide me or from experience tell me the issue with +38 offsets. I was reading that It would require wheel spacers. 15mm correct? Anyone have pics of this +38 and spacer setup? Just trying to find some certainty and will order. Just frustrating as the RPF or whatever wheels that everyone seems to like are of no appeal to me. Love the classic 5 spoke and open to other options but thus far TS-5's have me sold but I don't want the car to look bad. To add, I saw that it was mentioned this thread is mainly for the Enkei racing line but don't know where else to post. Apologize and/or thanks in advance guys.
Old Mar 20, 2023 | 01:57 PM
  #2849
Heel Til I Die's Avatar
Heel Til I Die
Aesthetically, +38 is going to have the wheels and tires look sunken in and not flush with the fenders.
@MicVelo will chime in with a more scientific explanation concerning scrub radius, etc.
Old Mar 20, 2023 | 07:06 PM
  #2850
MicVelo's Avatar
Thanks, Heel but there's really no need to even get into scrub radii since the OP already knows he needs to "correct the offset" with spacers.
@ORNG350 An offset above +30F/+33R will tend to move the wheel/tire inboard; hence Heel's comment about being sunken in. While it's better to buy "the right offset" wheels to start, there's nothing horrible about running conservative spacers for fitment. I used to be a doubter and naysayer - until I tried my first set, coincidentally on my first Z33 (the one I still own) - but after the positive experience I had with getting my tires and wheels perfectly dialed in and opening up my choices of wheels, I use them without any reservation.
For your application 8.5/9.5 +38 F/R, I'd go with either a 15 or 20mm spacer. Make sure whatever spacer you get, they are hub-centric for your Z's hubs which are 66.1mm. The wheels (TS-5) have a 72.6mm center hub hole so you will need hub ring adapters (plastic or aluminum, your choice) to fit the hub-lip of the spacer. You will need a set of 72.6 to 66.1 hub ring adapters. And, by the way, these are the exact spacers I use with nary an issue. Reason I posted the link is so you can see the hub-lip I'm talking about.
Pairing tires with your TS-5s, use a 245/40-18F, 275-40-18R and you'll be set.
If you want to learn more about offset, here's a bump of my old post. Might help a little.
Robert_K
Texas
40
Aug 1, 2009 03:45 PM
bilinghm
Jan 27, 2006 05:58 AM
mario60185
Mar 31, 2005 04:41 AM
