Unofficial Enkei Wheels Thread
May 21, 2012 | 03:51 AM
Jun 7, 2012 | 11:55 AM
So finally got a set of RPF1s for real after many years of putting them on cars in video games.
18x10.5 square set up with 265/35. I stayed up late at night and spent hours looking at the two 10.5s I had mounted up front and researching on here to see if I should go square. I'm very happy with it and can't wait till the 17th to really test them out.
Can't wait till the apron is paved and quits sinking.
Jun 9, 2012 | 02:18 PM
lower springs and ur set unless u want to go crazy low other than that
Jun 9, 2012 | 04:29 PM
I'm still debating on what I want to run suspension wise. But by the end of the summer that rear gap will be at a more acceptable level.
Also, a fresh detailed picture since the car was pretty dirty in the previous.
Jun 9, 2012 | 04:30 PM
here are my 2 piece rpf1-rc rims 19x9 +18 front and 19x10 +22 rears.
Jun 10, 2012 | 07:26 AM
RPF1 18x9.5F 18x10.5R
Nitto Invo 255/35F 295/35R
Got 2nd place at this show under a single turbo supra
Jun 10, 2012 | 08:06 AM
Quote:
Originally Posted by
RENFRO
What are your camber specs with the 295 rear?
Jun 10, 2012 | 10:52 AM
Super Moderator MY350Z.COM
harman850t5
You can run taller tires , 285/35 front and rear will close the gap a bit.
Jun 10, 2012 | 01:29 PM
Senior Super Moderator MY350Z.COM
Jun 10, 2012 | 03:38 PM
Chi-TownWarrior
Currently however the factory spec landed after lowering it. I have a camber kit and toe bolts ready to go on. I'll let you know after all that is done and I get an alignment
Jun 11, 2012 | 10:37 AM
R6n350GT Very nice, did you happen to weigh those before throwing them on?
Jun 12, 2012 | 12:58 PM
Somewhere in the Appalachians.
Jun 12, 2012 | 02:56 PM
Jun 12, 2012 | 04:19 PM
MOAR!!! Is that painted? Powerdercoated?
Edit: Was that originally SBC finish? Details please!
Jun 13, 2012 | 08:07 AM
I need to lower the rear a tad more, but I am very happy with it so far!
Jun 13, 2012 | 09:08 AM
tim_nwh
looks like you need tires, probably better off just getting proper tires, they will fill the wheel well a lot better.
Jun 14, 2012 | 08:07 AM
I want a little bigger tire in the rear. I am still tinkering with it.
Jun 17, 2012 | 09:00 PM
I need to lower the rear a tad more, but I am very happy with it so far![/QUOTE]
now i want some rpf looks ****en sexy!!!!
Jun 18, 2012 | 07:24 AM
I think I am actually going to raise the front a little bit, bigger tire in the rear and a spacer. should be set then
Thank you for the compliment.
Jun 18, 2012 | 07:51 AM
