Unofficial Enkei Wheels Thread
Old 08-02-2015 | 06:52 PM
  #2401
K-Pac's Avatar
K-Pac
Default RPF-1 Fitment
Hi all. After a relatively exhaustive search, I'm making a new thread for a fitment question.
I currently have an all stock 08 350z with no adjustments made in the suspension.
Here is the potential setup:
17x10 +18 with 235/40/17 tires
18X10.5 +15 with 255/35/18 tires
The set of four is listed for $1300 with new tires so it sounds like a good deal. My search has shown mixed results with some arguing that the fronts may need the fenders rolled and the rears with an added spacer. How does everyone feel about this setup on our vehicles?
Note: I would like to stay on stock suspension but obviously not drive a 4x4. The vehicle is mainly used for daily driving with annual trips to the local road course.
Thanks for all your help.
Old 08-02-2015 | 09:17 PM
  #2402
MicVelo's Avatar
350Z/370Z Tech Moderator
Front: reduction of inside clearance by 13mm, outboard, add additional 37mm. Front wheelwells are already flat from factory, no roll required.
Rear: Reduction of inside clearance by 10mm, outboard, add additional 40mm.
In the future, use the tool:
https://my350z.com/forum/tire_rim_calculator.php
Take the results of this and a tape measure out to your car and that should give you a pretty good idea of fit.
Old 08-02-2015 | 09:24 PM
  #2403
mr. sparco's Avatar
mr. sparco
Those are weak tire sizes.
Old 08-02-2015 | 11:21 PM
  #2404
DesertSleeper's Avatar
DesertSleeper
The front stock tire is a 225/45r18, which has a diameter of 26", a 235/40r17 tire has a diameter of 24.4". The rear stocker is a 245/45r18 which has a diameter of 26.7", a 255/35r18 has a 25" diameter. While this would lower u .8", it would also add another .8" wheel gap to ur already 4x4ish stock gap. Not a good idea. To avoid furthering ur 4x4 stock gap look, stick to stock tire diameters....
Old 08-04-2015 | 12:34 AM
  #2405
DesertSleeper
Old 08-05-2015 | 05:05 AM
  #2406
Canada_Z's Avatar
Canada_Z
superlim9 (08-20-2015)
Old 08-05-2015 | 07:02 AM
  #2407
lifekenophobic's Avatar
lifekenophobic
Originally Posted by Canada_Z
Love this fitment. What brand/size tires are you running, if you don't mind me asking?
Old 08-05-2015 | 12:50 PM
  #2408
DesertSleeper
I'm gonna guess 265/35 up front 285/35 rear....looks great
Old 08-06-2015 | 09:31 AM
  #2409
Canada_Z's Avatar
Canada_Z
Its 275/35 square Dunlop Star Spec 2's. 15mm spacer in the rear.
18x10.5 square.
Old 08-06-2015 | 09:38 AM
  #2410
DesertSleeper
18x10.5 square.
Very nice......what kinda drop if that?
Old 08-06-2015 | 11:56 AM
  #2411
Canada_Z's Avatar
Canada_Z
Around 1.5"
Old 08-06-2015 | 07:13 PM
  #2412
ap2_S2Kyle's Avatar
ap2_S2Kyle
Old 08-06-2015 | 07:29 PM
  #2413
DesertSleeper
Originally Posted by ap2_S2Kyle
Looking good Florida orange, looking good.......
BigBlue (08-06-2015)
Old 08-19-2015 | 07:57 PM
  #2414
Austin88's Avatar
Austin88
Question RPF1s on a 350z!?
I have a predicament here... I saw some Enkei RPF1s and became obsessed with them. I think bronze would look awesome on my silver z. I know bronze RPF1s are almost impossible to find in the right sizes but I can get another color powder coated bronze.
Here is the issue, Enkei only makes two RPF1 size groups that I calculated would be best for my Z.
1.) 10" +38mm (Front) which would retract my current setup by 4mm, and 10.5" +15mm (Rear) which would extend my current rear setup by 8mm.
2.) 9.5" (All Around) +38 offset in the front retracting my setup by 10mm and +15 in the rear retracting my current setup by 5mm.
I was thinking of selling my Volk SF Challenge wheels to buy the RPF1s and some new tires but I am not sure if it is worth it. I really like how they sit now with stock suspension. My current wheels and tires are 9.5" +28 Front, forgot the tire size, and 10.5" +23 Rear 285/35/ZR19 tires.
Does anyone think +/- 5mm to 10mm offset would make a huge difference in appearance? Is it ok to switch to a square 9.5" setup? What would you recommend doing?
Thanks!
Old 08-20-2015 | 01:41 AM
  #2415
terrasmak's Avatar
Austin88, the most common RPF1 combo is 9.5 +15 front and 10.5 +15 rear. Some of us have been running 10.5 +15 all around. Look around in this section for examples
Austin88 (08-20-2015)
Old 08-20-2015 | 03:37 PM
  #2416
Austin88's Avatar
Austin88
Thanks terrasmak, is there any reason not many people run the 10" +38 RPF1 in the front with the 10.5" +15 in the rear? I just noticed that there is less of an offset difference with the 10" wheel for the front.
Old 08-20-2015 | 03:47 PM
  #2417
nextcore's Avatar
nextcore
ive ran 18x10.5 +15 on two different sets of wheels. (new set of wheels coming and both front and rear will be identical)
For me, running 10.5 +15 all around is solely because i can rotate the wheels and tires front to back. I think a lot of the guys that run square set-ups can attest to this, it's the biggest benefit to get the most out of their tires.
Old 08-20-2015 | 04:09 PM
  #2418
Austin88's Avatar
Austin88
nextcore, that makes sense haha I wouldn't mind doing that. I am pretty new to wheel sizes because I bought my car with aftermarket wheels already installed.
I believe the 10.5 +15 would extend about one inch further in the front than what I have right now. Do your front wheels extend beyond the fender? What tire size do you run?
Thanks!
Old 08-20-2015 | 04:14 PM
  #2419
Spike100's Avatar
Spike100
10" +38 on the front will appear "tucked." It will not look good on a 350z.
Old 08-20-2015 | 04:22 PM
  #2420
Spike100's Avatar
Spike100
10.5" +15 will protrude slightly on the front. 9.5" +15 aligns with the front fenders almost perfectly.
Thanks!
Quick Reply: Unofficial Enkei Wheels Thread
