Unofficial Enkei Wheels Thread
#2581
been rocking the rpo3 for a couple years, been great. had to repair only 2 wheels due to hitting a rumble strip too hard. i dont see many SBC rpo3 out there.
NA&CH (06-27-2016)
#2583
No such thing as extended lugs
If you mean studs there should be no reason if you have the right lugs
#2585
That's not an extended lug
It's called a ET lug.....I have been on wheels and tires for years
#2587
I'm thinking OP means studs. Then I assume it's cause his lug nuts don't have enough threads cause they aren't the right ones
Or. He means open ended tuner type lugs that need a long skinny tool to fit in the whole in the wheels since stock 13/16 or 21 doesn't fit very good
All just guesses here
#2590
Yeah flat wheel face plus low offset equals huge back pad
NA&CH (06-29-2016)
superlim9 (07-21-2016)
#2593
350Z/370Z Tech Moderator
Talk about "bad influence"... When I get home in August, maybe I'll sell off everything (but my S-Tunes) and start over. Laff....
Not.
Rather "start over" with new vehicle....
dboyzalter (06-30-2016)
#2595
