Unofficial Enkei Wheels Thread
Old Apr 28, 2011 | 11:52 AM
  #781
Junkster's Avatar
Junkster
Originally Posted by AadosX
Tire rotation is overrated unless you just really like changing the type of tires your run a lot. Same sized tires on staggered wheels looks dumb IMO, but that's just me. Get a square setup if you want to run the same sized tires. And 245s on a 10.5?.. lol, really?
Did you even read what i posted?
this IS a SQUARE setup...and the tires are just a plus that come with the deal...I plan on running 265 35 18's all around after i save up money for the two other tires...
Im just asking if it would work for the time being with 245 40 all around....
Old Apr 28, 2011 | 12:49 PM
  #782
AadosX's Avatar
AadosX
Ok, my bad. Well I think 245's will look ridiculous. If I were you I'd run 275/35 all around for a square setup on 10.5's, but then your rear tires will be VERY short.
Old Apr 28, 2011 | 12:53 PM
  #783
Junkster's Avatar
Junkster
Im not saying its going to look awesome either lol...but i figured with a 40 series the 245 wouldnt looke TOO stretched...im planning on doing 265/35 for sure though...maybe someone on here will buy the 245 40s offa me and then i can get the other two 265/35s
Old Apr 29, 2011 | 06:50 AM
  #784
BSERIEuS's Avatar
BSERIEuS
someone is running 265/35's all around on his 18x10.5 rpf1 setup. i can't remember his SN though. i think its barefootracer or somethin like that.
as far as 245/40's all around...i haven't come across that. i did come across a few posts of 255/40 all around. not sure if it was a 18x10.5. it could have been a 18x9.5?
either way...265/35 seems all right. 285/35 sound better. i think Lgear runs that setup.
Old Apr 29, 2011 | 07:06 AM
  #785
Barnabas's Avatar
Barnabas
National Z Club President
I'm running 285 all the way around on my 10.5's
Old Apr 29, 2011 | 07:41 AM
  #786
acke15's Avatar
acke15
I have 275/35/18s all around on 10.5" rim.
Old Apr 29, 2011 | 07:44 AM
  #787
scotts300's Avatar
scotts300
Cuz we ballers, and that's how we roll (trying to sound tough - don't think it's working).
Old Apr 29, 2011 | 07:49 AM
  #788
scotts300's Avatar
scotts300
Yes, no problem with it's functionality, though that stretched tire look is the ghay. Alternatively, you could sell the 245/40s and buy another pair of the 265s. The 245/40 is stock size on the NISMO front, so if they are in good condition without crazy inner tire wear from your S13 buddy, they should sell pretty easily. You could also go to a larger tire, as others have said.
Old Apr 29, 2011 | 08:40 AM
  #789
acke15's Avatar
acke15
What offsets do you have?
Old Apr 29, 2011 | 08:48 AM
  #790
scotts300's Avatar
scotts300
Which set?
18x9.5 +15
18x10 +38
18x10.5 +15
18x8.5 +40 / 18x9.5 +15
Old Apr 29, 2011 | 08:54 AM
  #791
acke15's Avatar
acke15
Which set?
18x9.5 +15
18x10 +38
18x10.5 +15
How do the 18x10.5 +15 sit in the front? I have this setup, and the front sticks out by 1/2-1"
Old Apr 29, 2011 | 10:41 AM
  #792
scotts300's Avatar
scotts300
They sit just fine with my 285/30s up front. I do have some camber though.
There are more here, and the 18x10.5 +15 set is any pictures with the black wheels.
Old Apr 29, 2011 | 10:49 AM
  #793
acke15's Avatar
acke15
They sit just fine with my 285/30s up front. I do have some camber tho]
that's strange... I still have stock a arms. I'm within spec on camber right now. I have spc arms that are going on with coils next week. I wonder why minevis sticking out a little
Old Apr 29, 2011 | 11:06 AM
  #794
scotts300's Avatar
scotts300
Camber.
I PM'd you about 3 other options as well.
Old Apr 29, 2011 | 11:28 AM
  #795
BSERIEuS's Avatar
BSERIEuS
Camber.
i'm not sure if you mentioned how much camber you're running up front.
but..what is your camber settings up front?
you can PM me if you don't want it out there.
thanks in advance.
Old Apr 29, 2011 | 11:59 AM
  #796
terrasmak's Avatar
Not your typical street setup, but i run -2.7 up front and can clear my 275/40-18's on 10.5 +15 if i had to. I'm sure Scott is pretty somewhat close to me in camber.
  #797
scotts300's Avatar
scotts300
thanks in advance.
It's no problem. I run about 3.3 degrees of negative camber on the front, and caster is maxed with a touch of toe out.
Old May 4, 2011 | 08:39 AM
  #798
BSERIEuS's Avatar
BSERIEuS
i recently dropped my car on eibach sportlines and my front camber is 1.8 and rear 2.7.
im assuming that i will not be able to acheive 2.5 camber on the stock arm unless i was super slammed? (figuring that the lower you are..the more your wheels camber in)
if i could get my front camber to even out with the rear on the stock arms that would be great. i'll go get it done at NTB today! haha
Old May 4, 2011 | 09:16 AM
  #799
terrasmak's Avatar
You need a set of front arms. We get camber gain as it compresses as you know. Just because you would have more camber from going lower doesn't mean you will clear, you need more camber at your non compressed setting to clear.
Old May 4, 2011 | 09:39 AM
  #800
BSERIEuS's Avatar
BSERIEuS
You need a set of front arms. We get camber gain as it compresses as you know. Just because you would have more camber from going lower doesn't mean you will clear, you need more camber at your non compresses setting to clear.
thank you! this is exactly what i needed.
