Unofficial Enkei Wheels Thread
Old May 17, 2011 | 02:54 PM
  #841
SE5spd's Avatar
SE5spd
Im on swift spec R
Originally Posted by jkim824
Nice, What are you lowered on?
Heres mine:
Old May 21, 2011 | 08:02 AM
  #842
yellowxhoodie's Avatar
yellowxhoodie
Old May 21, 2011 | 09:57 AM
  #843
Zazz93's Avatar
Zazz93
Why would anyone want their car that low
Old May 21, 2011 | 01:20 PM
  #844
acke15's Avatar
acke15
i thought i was low, and im nowhere near that low.. i was rubbing and scraping all day long. he's gotta b doin the same thing but worse.
yellow- whats your tire specs?
Old May 21, 2011 | 03:05 PM
  #845
G4nismo's Avatar
G4nismo
bought the last pair of 19x10 +22 from tirerack and 19x9.5 +22 are on the way.
enkei won't be making in these specs (19'') anymore.
CIMG2686.jpg?t=1306017592
Old May 21, 2011 | 04:16 PM
  #846
mr.elite's Avatar
mr.elite
It's made by Enkei so here it goes. AME TM02. 19x9.5 19x10.5 +22
Old May 21, 2011 | 05:12 PM
  #847
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I saw they were on clearance for $450 per wheel which is odd because they were always $450 even before the clearance price
At any rate, if they are stopping production of the 19" line then that should make my wheels all the more valuable
Old May 21, 2011 | 08:16 PM
  #848
G4nismo's Avatar
G4nismo
It was more like a close out price but the price was still the same. Doesn't really makes sense but i'm glad i got the last set.
yeh, it should def make the 19s more valuable now.
Old May 22, 2011 | 05:58 AM
  #849
Zazz93's Avatar
Zazz93
...but i'm glad i got the last set.
Tread lightly, a pot hole could really screw up your day.
Old May 22, 2011 | 06:01 AM
  #850
scotts300's Avatar
scotts300
Exactly my concern on a discontinued wheel.
Old May 22, 2011 | 06:16 AM
  #851
yellowxhoodie
18x9.5 +15 225/40 F
18x10.5 +15 255/35 R
Old May 22, 2011 | 07:11 AM
  #852
terrasmak's Avatar
Originally Posted by yellowxhoodie
18x9.5 +15 225/40 F
Wow, civic sized tires, and you couldn't even figure out that you should have run a 255/40 rear to match the lame from size you picked.
Old May 22, 2011 | 08:13 AM
  #853
G4nismo's Avatar
G4nismo
duly noted
Old May 22, 2011 | 10:02 AM
  #854
scotts300's Avatar
scotts300
18x9.5 +15 225/40 F
Front tire is taller than the rear; do not like. I was curious when I saw the rake, as it looks like the overall rear height (ground to fender) is higher in the front. Have you measured?
Old May 22, 2011 | 11:35 AM
  #855
Zazz93's Avatar
Zazz93
18x9.5 +15 225/40 F
You never know what the actually diameter of the setup is... with tires stretched two sizes more than a recommended max stretch, that diameter could be .500+ inch shorter.
Still funny to see how impractical people get with their sizing and fitment.
Old May 22, 2011 | 04:15 PM
  #856
SE5spd's Avatar
SE5spd
Well this is a bit annoying, my F/R were both rubbing..got my rears rolled and have a rear SPC camber kit on the way, my front still slightly rubs maybe one time a day but still annoying when it does.
So my question is do I have to get a front camber kit to solve the problem or is there any other way?
Old May 22, 2011 | 04:31 PM
  #857
03threefiftyz's Avatar
03threefiftyz
Lets get a bit of function back in this thread....
From the National at Summit Point this weekend.
Brian Kleeman in T3 trim (limited to 8.5" wide wheel and 245 A6's):
Rob Hines in T3 trim....Race winner as well:
Neither raced T2 (unfortunately they were in the same heat)...so no pics with 10" wide wheels and 285 A6's.
Also some 300zx **** for our recently promoted super mod, scotts300:
Old May 22, 2011 | 04:34 PM
  #858
Anomaly's Avatar
Anomaly
That's too bad.
I was debating on getting the 19x10 +22 for the fronts but I guess I wont be doing that now.
And that was the second thought that came to mind!
Old May 22, 2011 | 07:05 PM
  #859
scotts300's Avatar
scotts300
Originally Posted by scotts300
I have personally seen 275s rub on a Z with 9.5 +15s. It was only lowered. It needed the fenders rolled. They were Kumho XS 275s.
There is no other way. Those RS3s run wide, as do many of the competition-type tires these days. Only way is to change tires, have the wheel machined, or dial in some camber.
Rob and Bob are good dudes. And thanks for Z32 **** - I love it. Those are some big wheels. It's very hard to make Z32 TTs work as track cars. . . reliably at least. That's why mine is only going to go hard for ~10s at a time any more.
Old May 22, 2011 | 07:21 PM
  #860
03threefiftyz
It was a tube frame GT2 car.....sequential trans and the whole deal.
