Unofficial Enkei Wheels Thread
Old Jan 15, 2009 | 03:02 PM
  #81
Clipdin's Avatar
Clipdin
SHIFT_happens
Geez, that offset is HUGE!!! Hope they are cheap!
Old Jan 15, 2009 | 03:03 PM
  #82
Gag83's Avatar
Gag83
look for a different set, if u want enkei try the RPFO1's they are nice wheels and our vendors on here have em for an affordable price
Old Jan 15, 2009 | 03:16 PM
  #83
350z 1962's Avatar
350z 1962
400.00 for set plus $ for spacers?
Old Jan 15, 2009 | 04:42 PM
  #84
350Ricky's Avatar
350Ricky
I like Rice
youre gunna probably need a 30mm spacer. Id say just get some wheels with a better offset
Old Jan 15, 2009 | 04:47 PM
  #85
MyV6IsFast3r's Avatar
MyV6IsFast3r
Buddy of mine had those on his Sunfire.
Not worth it at all IMO.
Old Jan 15, 2009 | 04:59 PM
  #86
mcarther101's Avatar
mcarther101
I'm running 19x8.5 +42 245/35/19 19x9.5 +42 275/30/19 Enkei GTC01's. Here are a couple pics I found real quick, hope it helps your decision. They sit further out than OEM wheels. Could use spacers, but not absolutely necessary. Still looks good, and I get compliments on the wheels/car. Here are some pics for comparison.
My wheels are wider however, 8.5 and 9.5 vs 8. An 8 inch wide rim will be sunken in more, so you're more likely to need spacers than me. Spacers run around $100 for hubcentric per axle, cheaper than $2k+ rims.. then again mine were $2k anyway, I just liked them.
My car/wheels:
Stock wheels for comparison:
Old Jan 18, 2009 | 03:17 PM
  #87
widesti's Avatar
widesti
Default Unofficial Enkei Thread
i purchased a set of used enkei rpf1. however they did not come with hubcentric rings. i did some searches and many said, though it is not necessary if you tighten it down in the right manner, it is recommended to run hubcentric rings. what size/brand should i get? is 66.1 x 73.1 the correct size? is that front and rear or just one? thanks
Old Jan 18, 2009 | 05:51 PM
  #88
str8dum1's Avatar
str8dum1
yes, you should run hubcenttric rings. you dont want teh lugs to be the primary load bearing source (lug centric, which u currently have). any place that sells them, knows what size you need for those rims, but what you listed could certainly be it as we have 66.1 hubs.
Old Jan 18, 2009 | 05:53 PM
  #89
r_seng's Avatar
r_seng
I'm a little confused about your situation, if I'm reading this right, you bought a set of used RPF1s with a bore that isn't Z fitment?
Old Jan 18, 2009 | 07:11 PM
  #90
Don't know the bore of the wheel but the hub is 66.10mm front and rear.
Old Jan 18, 2009 | 09:02 PM
  #91
widesti's Avatar
widesti
i think the enkei bore is 73mm. so what size do i look for?
Old Jan 18, 2009 | 09:25 PM
  #92
Anomaly's Avatar
Anomaly
Here is Enkei's list of critical dimensions and data for the RPF1 rims:
http://www.enkei.com/RacingSeriesSpecs/RPF1.html
Looks like their typical bore diameter is 73mm. As stated, the Z bore is 66.1. You should be looking for rings that fill that space. ~73 mm OD x ~66.1 mm ID.
I cannot help with brand selection, but there are a couple different varieties available:
Aluminum
Plastic
Old Jan 18, 2009 | 10:12 PM
  #93
widesti's Avatar
widesti
they sell hubcentric rings at america's tire im going to see if they have the correct set available there tomorrow.
Old Jan 19, 2009 | 07:04 AM
  #94
300zx1985's Avatar
300zx1985
I was about to order some for my RPF1's too. I have had them mounted for about 3 weeks now, I am having no issues running no hubcentric rings. Would you guys reccomend plastic or aluminum ones? (no thread jack OP can benefit too)
Old Jan 19, 2009 | 08:02 AM
  #95
Beau's Avatar
Beau
Get plastic rings since they can be manipulated a little if there is a slight variance in machining between the wheels and the rings.
Most aftermarket wheels do not come in the exact hub bore required for most cars so that the wheels will fit more cars.
Nissan hub bore is actually 66.06mm, but what is .04mm among friends. My hubcentric rings for my Rota's were 66.1 x 73mm for my 73mm hub bore on the wheels. I got them for $5.99 from National Tire. They are technically only supposed to sell to distibutors and retailers, but I have a friend that owns a Midas so he bought them for me.
Old Jan 20, 2009 | 12:09 AM
  #96
widesti's Avatar
widesti
it does not matter if you get them exact brand to the wheels. order it from the manufacture or from america's tire. both have exact sizes. i am having no issues at all. if you tight the lugs correctly it should be okay, but id rather be safe than sorry.
Old Jan 20, 2009 | 04:31 AM
  #97
Beau's Avatar
Beau
Doesn't that defeat the purpose if they don't fit exactly? If they aren't fitting snugly they may as well not be there at all. Close counts in horseshoes and hand grenades as they say.
Old Jan 20, 2009 | 12:10 PM
  #98
widesti's Avatar
widesti
oops sorry, i meant exact brand to wheels. yes you need to get them exactly haha, it was late
Old Jan 21, 2009 | 10:40 AM
  #99
Done Deal DR's Avatar
Done Deal DR
Check this out:
http://www.rhdjapan.com/jdm-low/Rays-Hub-Ring-56755
ONLY $20 a piece.
Old Jan 21, 2009 | 03:36 PM
  #100
UnFairLady Z's Avatar
UnFairLady Z
what r these rings 4
