Unofficial Enkei Wheels Thread
Old Mar 29, 2014 | 06:42 PM
  #2081
08redHR's Avatar
08redHR
Originally Posted by bgood
need to lower it a little more... and it will look baddddddd
I thought about it, but I already scrape as it is. I have shitty inclines going into the parking lots at work and tons of speed bumps everywhere... Would take so much more effort if I go lower.
Old Mar 29, 2014 | 07:49 PM
  #2082
Underscore_Hero's Avatar
Underscore_Hero
Originally Posted by 08redHR
Posted these elsewhere on the forum, but figured they also belonged here.
18x10.5 +15 red with 285/35/18
18x9.5 +15 front with 265/35/18
Hey man, do you get rubbing on the front or back? like over rough roads?
I'm thinking about a similar setup:
18x8.5 +15 - 275/35/18
18x10.5 +15 - 315/30/18
Do you think my rear tires would cause issues? rub or vdc?
Tire calc shows 40mm/49mm poke and 10mm/13mm inset from stock 17"s.
Old Mar 29, 2014 | 08:03 PM
  #2083
08redHR's Avatar
08redHR
Fronts shouldn't rub at all depending on ride height, the rears will depending on ride height and alignment specs. 2 degrees camber in back and lowered 1.5 degrees camber in front and lowered. I don't have the rear fenders rolled yet and I rub lightly over rough bumps. 95% of the time though I don't rub at all with my current setup. Then again we have relatively smooth roads here in Phoenix. Also as far as I know our cars come with already rolled front fenders so that's a bonus.
Old Mar 29, 2014 | 08:13 PM
  #2084
Underscore_Hero
I'm at stock height and plan to stay that way for a while, recon laws in hawaii are a ***** to deal with.
Old Mar 29, 2014 | 08:38 PM
  #2085
08redHR's Avatar
08redHR
I doubt you will rub then. You could actually go 315/35s in the rear as well with stock ride height Im sure.
Old Mar 29, 2014 | 11:25 PM
  #2086
terrasmak's Avatar
i would do a 9.5 +15 front and I would probably get a different 10.5 like the NT03 with a better offset for the rear to run wide tires. Even my 285/35's at +15 needed a really good roll and I have 7mm if I remove my 5 mm spacer
Old Mar 30, 2014 | 02:01 PM
  #2087
Underscore_Hero
Yah, I'm looking at a used set originally for a 370z.
I measured the poke and it's very close to the inside lip. No counting compression.
Old Mar 30, 2014 | 04:42 PM
  #2088
mr. sparco's Avatar
mr. sparco
Old Mar 31, 2014 | 11:57 AM
  #2089
CJM's Avatar
CJM
Looking for some insight. I am looking into RPF1s and have the Akebono BBK for the front. I know that 18x9.5 +15 clears just fine, but I am curious if 19x9.5 +22 would clear as well or if just a 5 mm spacer could allow for the clearance. I understand that the wheel will be set in an additional 7mm, but I do not know if the spoke design (concavity) changes. Any input would be helpful.
Old Mar 31, 2014 | 12:42 PM
  #2090
Underscore_Hero
How about a 18x9.5 255/40/18 square setup?
I prefer not to roll.
Old Mar 31, 2014 | 03:32 PM
  #2091
mr. sparco's Avatar
mr. sparco
Spoke/face does not change, x9 or wider have the straight spoke design. Just get the +15 if you're going to run +22 with a 5mm spacer, it essentially makes it +17.
Old Mar 31, 2014 | 04:55 PM
  #2092
CJM's Avatar
CJM
Thanks. I understood the offset differences, but was curious about the spoke design. Now I just have to decide what size I want...and keep saving
Old Apr 4, 2014 | 02:07 PM
  #2093
Spike100's Avatar
Spike100
OK… Let’s get provocative so that we don’t get boring…
I’ve read this entire thread (which is no small accomplishment) as well as the other long threads in this sub-forum about other wheel brands (which is a huge accomplishment). This thread (the Enkei thread) is loaded with useful information, and I rate it as the best Wheel/Tire thread on my350z.com. Moderator participation (some of our best moderators have been here the entire time) is what really makes this thread so useful.
So…. We need some controversy to complement the plethora of information here.
Here are some observations (that, of course, are arguable):
1. The Lightweight Racing Series from Enkei is unmatched. No other wheel manufacturer provides a better wheel if you compare price, weight, aesthetics, and durability (highly provocative statement).
2. Enkei has accomplished a very clean design (especially in the Lightweight Racing Series) that mates perfectly to the Z’s tasteful lines. The only other aesthetic competitor is Volk. Ugly wheels on the Z are very ugly.
3. Are forged wheels that much better (weight and strength) for the casual racer or the DD?
--Spike
Old Apr 4, 2014 | 03:12 PM
  #2094
mr. sparco's Avatar
mr. sparco
I use rpf1s for dd but have forged 3 piece 19s for show. Volks are awesome but can't beat Enkei's price point for weight, sizing, and durability.
Old Apr 4, 2014 | 05:22 PM
  #2095
pyshin's Avatar
pyshin
Second.
And I'm biased. But I don't care.
Old Apr 5, 2014 | 06:05 AM
  #2096
terrasmak's Avatar
--Spike
#1 I believe TSW and Konig have a wheel or two that are equal,just don't remember sizing. Enkei has our sizing down perfectly.
#2 All opinion, but Works , Advan and a few others make some kick *** wheels for the Z.
3. You will see more Enkeis on the racetrack on any given weekend of club racing and HPDE. We are either all doing something correct, or all wrong. Well with my budget and what I know about then, I'm on the right side.
Old Apr 5, 2014 | 05:57 PM
  #2097
Irontimmy's Avatar
Irontimmy
I've been stumped on choosing wheels, tsp6 gunmetal or rpf1's in hyper silver. Aiming for 18x 9.5 +15 squared. It's a chrome silver Z, all upgrades are bushings and suspension. So it looks pretty normal. Ive seen plenty of rpf1 pics and i know i can't go wrong with those, the enkei tsp6 look interesting though
Old Apr 5, 2014 | 06:00 PM
  #2098
Irontimmy's Avatar
Irontimmy
And this forum is so useful, i lack posts because most of my questions are answered when i search enough ^_^
Old Apr 5, 2014 | 07:07 PM
  #2099
sc300sted's Avatar
sc300sted
For those that are interested to see what the RS05RR looks like on a Z, here are some pics I found...
They don't list the specs of the wheels though.
http://advanceperformance.com/news/?p=3087
Old Apr 5, 2014 | 07:43 PM
  #2100
Spike100's Avatar
Spike100
^^ Thanks for posting the RS05RR pics. That is a great looking wheel, and it is very light weight.
