Unofficial Enkei Wheels Thread
Old Mar 18, 2012 | 07:42 PM
  #1201
Doh-Joe's Avatar
Doh-Joe
Anyone have pics of gold RPF1s on PPW? Just went through this entire thread and didn't find one.
Old Mar 18, 2012 | 09:09 PM
  #1202
Waiz's Avatar
Waiz
I don't know of anyone running that set either, you might want to ask for a photoshop in photoshop thread
Old Mar 19, 2012 | 05:13 AM
  #1203
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I don't think Enkei released gold in anything larger than 17".
Old Mar 19, 2012 | 08:15 AM
  #1204
Doh-Joe's Avatar
Doh-Joe
Yeah I just wanted to see the usual 18"- 9.5/10.5 - 15 offset in gold/PPW. Anyone?
Old Mar 19, 2012 | 07:22 PM
  #1205
yellowxhoodie's Avatar
yellowxhoodie
Old Mar 20, 2012 | 06:36 PM
  #1206
yellowxhoodie
Old Mar 20, 2012 | 07:13 PM
  #1207
lgear080's Avatar
lgear080
hot look yellow...
both the new looks are fireeeeeeeeeeeeee 18x11!!!!!!!!!
Old Mar 26, 2012 | 09:01 AM
  #1208
AznSky's Avatar
AznSky
Default 18x9.5 +15 RPF1 w/ 275/35/18 FRONT on stock camber anyone?
Simple question,
I'm looking for somebody that is/has run a 18x9.5 +15 rpf1 with 275/35/18 Hankook RS-3's or Star Specs in the front with around -1.0 camber.
I've heard the RS-3's run wide, and I know a few members have this exact setup but with over -2.0 camber which I can't get cuz I don't have camber arms right now.
Thanks.
edit: Worst case if I can't find anybody, I'll probably run 265/35's just to be safe.....
Old Mar 26, 2012 | 11:46 AM
  #1209
terrasmak's Avatar
265's will be safer, but just get front camber arms. You tires will last a lot longer, and give you much better grip.
Old Mar 26, 2012 | 11:52 AM
  #1210
805350z's Avatar
805350z
^that
Old Mar 26, 2012 | 01:24 PM
  #1211
fhumphrey04's Avatar
fhumphrey04
I dont have aftermarket camber arms up front and I'm running -2.1* of camber. Are you lowered or on stock height?
Anyways- my tires are 275/35/18 front on the RPF1 wheels you're talking about and I dont rub at all, though my fenders are rolled. I dont know about RS3 tires, but the Star Specs DEFINITELY run pretty wide. Mine are Vredestein Ultrac Sessentas, and I think their sizes are pretty true. If there was less camber up front they would be hitting my fenders for sure.
These pictures probably best illustrate what I'm working with:
Old Mar 26, 2012 | 04:24 PM
  #1212
AznSky's Avatar
AznSky
Yeah I'll be going with 265/35/18's after my current tires run out. Thanks for the help again terrasmak!
Old Mar 26, 2012 | 04:42 PM
  #1213
2TH PWR's Avatar
2TH PWR
i run 265s and there is tonnes of room
Old Mar 26, 2012 | 05:40 PM
  #1214
03threefiftyz's Avatar
03threefiftyz
No problem me thinks:
315 A6 on a 10.5" +15. Stock, unmolested front fenders. Still has factory fender wells, including every screw, tab, etc. No rub. Probably 1mm of clearance on the inside and less than that towards the fender. This was on "soft" springs, a conservative ride height, and -2.3ish camber.
Tricycle mode:
[IMG][/IMG]
Old Mar 26, 2012 | 06:51 PM
  #1215
DankZ07's Avatar
DankZ07
stock camber was ok on tanabe springs for me, once i dropped a little lower on bc coils....rub city. Went to 265.
I had 275 nitto nt05, 9.5 +15 rpf1
Old Mar 27, 2012 | 12:55 PM
  #1216
skitso1080's Avatar
skitso1080
I'm lowered on .6 Inches in the Front .8 inches in the rear.
I want to run 18x9.5 +15 in the front and 18x10.5 in the rear.
I also want to run 255/40/18 in the front and 275/40/18 in the rear.
From what I have read some people have gotten away with no rub with this set up, whiles others have said they rub. Who do i trust?
I want those tires sizes so the my VDC doesn't go whack.
Old Mar 27, 2012 | 01:46 PM
  #1217
AdvanZ33's Avatar
AdvanZ33
You shouldn't have any rubbing issues in the front. Some tires run wider than others though. I had the same set-up and 275/40 Bridgestone Potenzas didn't rub while the same size Sumitomos rubbed all day long.
Old Mar 27, 2012 | 02:17 PM
  #1218
skitso1080's Avatar
skitso1080
thanks so the fronts are goon and i should just expect some rub in the back, depending on tire manufacturer?
Old Mar 27, 2012 | 02:32 PM
  #1219
AdvanZ33's Avatar
AdvanZ33
Yup yup. I assume you're on stock camber arms?
Old Mar 27, 2012 | 02:37 PM
  #1220
skitso1080's Avatar
skitso1080
yup
