New wheels w/ aggressive offset......looking for tires
Old Jan 16, 2008 | 07:19 AM
buzzardmountain's Avatar
buzzardmountain
Default New wheels w/ aggressive offset......looking for tires
I'm dropped about an inch and I'm not looking for the super stretched look.
Wheels specs:
19's - 9.5 +12
19's - 10.5 +12
I'm thinking the 245/35 and 275/35 will look too stretched.........any thoughts?
Old Jan 16, 2008 | 07:27 AM
SuperBlack350z's Avatar
SuperBlack350z
275 series on my previous rims (10.5 rear) looked a bit stretched. The 245 on the 9.5 rim looked good though.
BhashaZ's Avatar
BhashaZ
The fronts will be a bit stretched. The rears not as much, but that's a normal size for 19x10.5 wheels. The other alternatives for the rear are 285/35 and 295/30.
Old Jan 16, 2008 | 07:30 AM
BhashaZ's Avatar
BhashaZ
Really? I think the 245/35 is more streched on the 19x9.5" wheel versus a 275/35 on a 19x10.5" wheel.
Old Jan 16, 2008 | 07:32 AM
SuperBlack350z
weird. I had 19x9.5 and 19x10.5 RH J8's. With 245/35/19 and 275/35/19 and the rear definitely looked more stretched. That's why some people told me to go with 255/285.
Old Jan 16, 2008 | 07:33 AM
Motormouth's Avatar
Motormouth
a 245 is really stretched on a 9.5... it's stretched on a 8.5!
you need to lower your car more with that bodykit you have.
Old Jan 16, 2008 | 07:41 AM
BhashaZ's Avatar
BhashaZ
Well, from my personal experience with 245/275, the 245 just seemed worse. So my next set I got a 255/275 combo, which seems to fit a lot better.
Old Jan 16, 2008 | 07:42 AM
OffsetZ33's Avatar
OffsetZ33
I run that size with 265/30/19 front and 275/30/19 rear right now and am quite low. I wanted a more neutral feel so I went with similar sizes front and rear, although I have had both 245s and 255s on the front and all looked fine.
Old Jan 16, 2008 | 08:45 AM
redlude97's Avatar
redlude97
255/35/19 and 285/35/19 will work with those offsets and good fender roll
Old Jan 16, 2008 | 09:14 AM
Zilvia's Avatar
Zilvia
the 245 will look good up front, but i would suggest 265 or 255 for the back if you wanna stretch.
my mom has 275 on 10.5 and it not much of a stretch.....but i guess it depends on how much stretch u want.
Old Jan 16, 2008 | 10:32 AM
helldorado's Avatar
helldorado
The 245 will be stretched on 9.5. The 255 is a better fit and will give slightly more neutral handling.
The key is to consider tire choice too. I ran 255/275 with GS-D3's and they looked stretched. When I switched to PS2's, they had a much wider tread section and did not have the stretched look.
PS2's on the left, GS-D3's on the right. Same wheel, same 255/35/19 and 275/35/19 sizes.
Old Jan 16, 2008 | 11:04 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Dude, hurry up and put it on. Remember, the sizes will vary by brand. I would just T1-R with 255/275.
Old Jan 16, 2008 | 11:40 AM
buzzardmountain
Shush.....
I should just go with the Toyo's......
Right now I'm considering the T1-R's, g-Force™ T/A KDW, and the F1's.......I tend to overthink everything....just like I did buying those wheels from you.
Old Jan 16, 2008 | 11:53 AM
Andy@Performance
Performance Nissan
Originally Posted by buzzardmountain
Shush.....
Just go with the T1-R's.
Old Jan 16, 2008 | 12:11 PM
status:one's Avatar
status:one
245 in the front
265 in the rear
Running this setup on my other car... not that stretched at all.
Old Jan 16, 2008 | 12:15 PM
buzzardmountain
Originally Posted by lookleft
245 in the front
265 in the rear
Edit.....I saw a different size....maybe you edited.
Old Jan 16, 2008 | 12:18 PM
status:one's Avatar
status:one
yes, i wrote the wrong size by accident.
I'm running 245 on a 9.5 and 265 on a 10.5 wheel on my other car.
Old Jan 16, 2008 | 12:22 PM
CAVZ33's Avatar
CAVZ33
Here:255/35/19 and 285/35/19 TOYO T1-R'S on 19x9.5/19x10.5 +22 all around.
Old Jan 16, 2008 | 12:29 PM
Zridder19's Avatar
Zridder19
244 and 275 should be good
Old Jan 16, 2008 | 12:37 PM
InZomniac's Avatar
InZomniac
Ya ya just stick some rubber on em all ready GEEZ!
I am playing cause I want to know what you got wheel-wise.
