Can/Should I use 18 touring wheel lug nuts on 19" iForged wheels?
Old Jun 15, 2003 | 10:53 AM
vics350's Avatar
vics350
Default Can/Should I use 18 touring wheel lug nuts on 19" iForged wheels?
I was wondering if the stock lug nuts and lock nut that I use on my 18" touring wheels will work with the 19" iForged Aero's I have on order and due soon.
Thanks for your help.
Vic
Old Jun 15, 2003 | 11:00 AM
mcduck's Avatar
mcduck
This should work fine. I was able to use the lugs from stock 18s on my iForged 18s. I can't imagine the 19s being any different.
Old Jun 15, 2003 | 12:31 PM
R1Rider's Avatar
R1Rider
I used mine, they seem to work fine.
Old Jun 15, 2003 | 12:40 PM
vics350's Avatar
vics350
Thanks.
Old Jun 15, 2003 | 02:46 PM
Ralphus's Avatar
Ralphus
You bought wheels that cost that much and you can't spend $20 on a set of lugnuts and locks?
Old Jun 15, 2003 | 03:22 PM
ares's Avatar
ares
Veteran
if they require special lugs they should include em....
the holes in the te37s are too small to fit the wrench that comes stock with the car, so they gave me new smaller lugnuts, of course I did have to buy a new tire iron to put them in...
Old Jun 15, 2003 | 03:52 PM
vics350's Avatar
vics350
Timeout.
I was only questioning if my stock lug nuts would fit the rims. I didn't ask iForged if I would need special lug nuts but knowing that quite a few members on this forum already have iForged's installed I figured I'd ask here first and get their comments. I would have no problem buying different lug nuts if I needed them.
Old Jun 15, 2003 | 10:30 PM
little_rod's Avatar
little_rod
Hmmm, do the stock lug nuts lock??? I should be getting my iforged 19s in soon, and I heard they don't come with locking nuts. If the stock lug nuts have locks and fit, that would help a whole lot.
Old Jun 16, 2003 | 07:19 AM
R1Rider's Avatar
R1Rider
My stock lugs did not lock. Not sure if it was an option from Nissan to get locking lugs.
Old Jun 16, 2003 | 09:58 AM
srobert910's Avatar
srobert910
Anyone know if the Ray's lightweight lugs or the Kyokugen lugs will work with the iforged wheels? The ray's sets are very expensive but look pretty cool and come with one 7 sided nut for each wheel. The Kyokugen lugs are all 7 sided, which seems to be the best for security.
Old Jun 16, 2003 | 11:22 AM
vics350's Avatar
vics350
The dealer installed one locking lug nut in each rim for me when I purchased my car. Don't know if this nut will fit the iForged's as it is larger than the standard lug nuts. I will check it out when my rims come in.
Obadabot
Jun 18, 2023 11:31 PM
