a few noobish questions--te37's
on
Originally Posted by onedirtyz
so what's the consensus? if i stay with 275's [which i am for now] and lower on gf210's [1" front, 1.2" back] i shouldn't rub, right?
if i go wider, even just to 285, it'll rub? [based on majority's experience]
on
Originally Posted by SuperBlack350z
why did you ask to roll your fenders awhile back in the south east section then?
and i was talking about her offsets, her suspension. Please read above.
thanks for checking up on me
![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
4:
i know for stock potenzas the optimal psi is 35 [with a max of 49]
the max on the direzza's [both fronts and rear] is 51.. how the hell do you figure out the optimal psi? i'm guessing somewhere around 35 or 36 as well...?
on
5. You wont mess up your suspension if you drive unalign, but you might see some uneven tire wearing espeically with the long drive that you have. Maybe you should avoid driving it for couple weeks. It is acutally a good idea to wait a week or two before you get alignement so the springs can settle in.
my car is dirty
on
the stock springs need to settle with new wheels?
or do you mean after i get the springs, let them settle for a week, then get it aligned?
good thing my mom's going to be out of town for a few days, i can borrow her car.
on
on
for question #4, maximum tire pressure has nothing to do with anything. Some will have higher, some lower. With your size tires and rim size, i like to put 33 psi myself. 34 in the winter. You really can't go wrong as long as you stay between the right pressures.
my car is dirty
on
gotcha.
new question:
gf210's or nf210's? i know the nf210's spring rates are closer to stock #'s, and probably the best for daily driving but.... i don't particularly mind a rougher ride [it's already more rough than it was, what with sway bars and the wheels]. what else are the pros/cons for the two?
new question:
on
gotcha.
new question:
new question:
Some people have had camber issues with the gf210 as well. A lot of people didn't, including me.
Of course, the Gf210 will look a lot better. Paired with my hotchkis sways, the handling felt REALLY good.
my car is dirty
on
this is going to be suchhhhhh a noob question but.. i'm not at home so i can't look it up in my books myself right now and i hate our search function so here goes... if the shocks wear out, isn't that going to adversely affect handling?? and i don't mean daily-driving/freeway/city streets handling, i'm talking about hairpin-turns-on-canyons handling. i don't want to fall off my beloved mountain roads
![Frown](https://my350z.com/forum/images/smilies/frown.gif)
on
You cant switch out the valve stems on the TPS units, the best you can do is paint them the color you want and/or add some nice rays valve caps. They are pretty much a one piece design and can't be taken apart. Last time I had my tires flipped, the shop actually broke one of the sensors by snapping off the stem part from the body of the unit...
#38
For Sale
![](https://my350z.com/forum/images/ranks/premier.gif)
on
Originally Posted by WPPJR30
I have (had
) 285/35/19 with the same wheels (TE's 10.5" +22) and I was only lowered on Hotchkis springs and I rubbed. I had to roll...
It's not exact though, because I believe MethodRN (if I'm not mistaken) is running the same set-up (LE's instead of TE's
) and he does not rub...
![](https://my350z.com/forum/images/smilies/icon39.gif)
As for question 2, the ray's valve stems can't be used w/ TPMS. The TPMS is one piece that can't be seperated.
