switching rear to front OEM wheels
I own an 03 touring. Is it possible to use a rear oem wheel for the front? I believe they are the same size. 18x8. Has anybody done this?
Originally Posted by Fairly Z
It's not the same size, it's a staggered offset. But, you can still use it. I've got 8.5s in the front and 9.5s in the rear.
not true. They are 18x8 all around.
The tires are different sizes but the wheels are exactly the same. So yes you can use a rear wheel upfront.
Don't forget to remove the little bolt sticking out of the front wheel hub. It's there to prevent you from accidently doing what you're talking about doing - swapping front to rear wheels.
^^preventative modderating
who says the mods aren't good around here?
I thought my stockers were different sizes? Maybe because mine's an '06 or am I just wrong?
The tires are definitely a different size, i.e. the staggered setup.
The 6-spoke stock rims are 18x8 all around.
The 7-spoke stock rims are 17x7.5 in front & 17x8 in rear.
The 6-spoke track rims are also staggered, 18x8 in front & 18x8.5 in rear.
bcoffee20
Nov 19, 2015 06:39 PM
xirtam
Oct 3, 2015 02:06 PM
Beater350z
Sep 9, 2015 03:36 PM
