17s or 18s
Old Jun 18, 2003 | 11:11 AM
350zroadster's Avatar
350zroadster
Default 17s or 18s
Hey guys
It just occured to me that if you intend to swap the wheels, it doesn't matter whether you get the stock 17 wheels or stock 18 wheels. The tire diameters are 666.8mm vs 677.7mm. Less than 11 millimeter difference, that's half an inch or less than 1% error.
So if you intend to upgrade anyways, you might as well go for 17s and save your dough. Am I missing something here?
Old Jun 18, 2003 | 11:21 AM
ares's Avatar
ares
Veteran
Im not following what your saying or asking...
but I think you logic is flawed somewhere...
please clarify.
for the record,
17" rims have 225/50 and 235/50. thats 112.5 and 117.5 sidewall. alright.
18" has 225/45 and 245/45, thats 101.25 and 110.25
for a difference of 11.25 and 7.25.
difference in rim size is 12.5mm/radius meaning fronts are damn near the same(2mm off), rears are about 10mm off being the same(18s being larger). but the sizes are as close to equal as you can get with standard tire sizes.
most upgrading are gettin 18s and 19s for appearance, not performance or cost issues, or because thats the size they started with.
Old Jun 18, 2003 | 12:16 PM
350zroadster
Ares,
Yes but I wasn't talking about tire height, I was talking about the overall diameter size. Since they are proximately the same size, someone with 17s can upgrade to 19s just as easily as others who went from 18s to 19s.
Old Jun 18, 2003 | 12:37 PM
Duck's Avatar
Duck
Well you've got the aesthetics of it bigger looks better on the Z, now when it comes to performance you'd want a smaller wheel with a larger tire on the rear if your drag racing, but if you wanted car control you'd want larger wheels with smaller tires.
Old Jun 19, 2003 | 12:44 PM
350zroadster
that has nothing to do with what I was talking about.
Old Jun 19, 2003 | 03:02 PM
ares's Avatar
ares
Veteran
I think we are trying to make your post more complicated than it is.
your saying that people with the 17" rims can use a 19" rims...
but thats obvious...
Old Jun 20, 2003 | 10:10 AM
350zroadster
Well I was under impression that the 17s "tire" are smaller than 18s. And with it, the data for TCD and VDS would be different. Well that's not the case.
350ZOWNZ
May 21, 2004 06:39 AM
joust75
Feb 29, 2004 03:54 PM
Mr_Q
Jan 31, 2004 09:25 PM
TaliaZ
Nov 28, 2003 03:02 PM
VQ35DES
Sep 22, 2003 02:30 PM
