Anyone with 265 or 275 rear, but OEM 18s?
Old Feb 5, 2008 | 11:34 AM
SniperHunter's Avatar
SniperHunter
Default Anyone with 265 or 275 rear, but OEM 18s?
Curious to hear some opinions and perhaps even see some pictures of the result.
Old Feb 5, 2008 | 11:46 AM
ZLadie2000's Avatar
ZLadie2000
+1 i'm curious how badly 275s will bulge (if at all on stock 18's.. 8.5 inch rears)
Old Feb 5, 2008 | 03:34 PM
SniperHunter
I don't believe they'll bulge. They will instead cave in a bit at the sidewall.
Old Feb 5, 2008 | 03:47 PM
redlude97's Avatar
redlude97
They WILL bulge
Old Feb 5, 2008 | 03:48 PM
SniperHunter
That's interesting. How come? I thought they'd only bulge if my rim was too wide.
Old Feb 5, 2008 | 03:52 PM
redlude97's Avatar
redlude97
You might want to look up the definition of bulge, based on what you posted above, you are confusing bulge with stretch
Old Feb 5, 2008 | 04:00 PM
SniperHunter
I think I understand what you mean by bulge, now. The tire will protrude over the rim, correct? If so, that's what I meant by the sidewall being caved/angled inward, creating a protrusion.
Old Feb 5, 2008 | 04:30 PM
redlude97's Avatar
redlude97
Here you go
Old Feb 5, 2008 | 04:34 PM
Spike100's Avatar
Spike100
Arnie,
Redlude97 is correct. And, I suspect he is becoming somewhat frustrated trying to explain this to you.
If you mount a tire that has a section width that is wider than what the tire’s manufacturer specifies (i.e., a 275/40-18” tire on a 18x8.5” rim when it should be on at least a 18x9” rim), the tire will “bulge” a little and have a more convex side-wall profile.
--Spike
_____________________________
EDIT: Just noticed redlude97’s great graphic that appears above my message. His picture explains it (and saves a thousand words).
Last edited by Spike100; Feb 5, 2008 at 05:10 PM. Reason: to mention redlude97's good graphic
Old Feb 5, 2008 | 05:07 PM
PDX_Racer's Avatar
PDX_Racer
My '05 Track model on 245/40R18 fronts and 275/40R18 rears:
If I didn't tell you that they were 275s, you probably couldn't tell...
Old Feb 5, 2008 | 05:10 PM
Sea Bass's Avatar
Sea Bass
Yeah, but track rims are wider than non-track OEMs, no? I mean, the they come with 265 rears vs the 245 rears the rest of us get.
I don't understand the appeal of wider tires on OEM wheels? If you want wider tires why not do it right and get wider wheels? Confused.
Old Feb 5, 2008 | 05:13 PM
redlude97's Avatar
redlude97
Thats pretty easy to tell, you can see the difference in bulge from the front to the rear
Old Feb 5, 2008 | 05:14 PM
redlude97's Avatar
redlude97
Not the older track wheels, 18x8f 18x8.5r 225/45/18 245/45/18
Old Feb 5, 2008 | 05:15 PM
whitt1's Avatar
whitt1
I'm running 265/35-18f and 275/30-19r RE-01Rs on my stock Nismo wheels.No issues at all.
Old Feb 5, 2008 | 05:23 PM
redlude97's Avatar
redlude97
Nismo wheels are 18x9 19x10, not applicable in this situation
Old Feb 5, 2008 | 05:26 PM
Spike100's Avatar
Spike100
Phil,
That wasn’t Arnie’s (the OP) question. Arnie asked for pictures of a 275 or 265 on a 18/8.5” rim.
And, PDX Racer made the effort to post a picture showing what the OP asks to see.
I would thank PDX Racer for taking the time and effort to post a good picture. I'm sure Arnie also is appreciative.
Jeez Phil… “listen-up”
--Spike
Old Feb 5, 2008 | 05:43 PM
Spike100's Avatar
Spike100
Huh?
Nismo doesn't have a 9" width or a 10" width wheel for the Z.
Nismo wheels are front 18x8.5” and rear 18x9.5”, or the same widths in Nismo 19” wheels.
--Spike
Old Feb 5, 2008 | 05:48 PM
redlude97's Avatar
redlude97
Originally Posted by Spike100
Huh?
--Spike
The nismo edition Z wheels have the same specs as the 06+ GT wheels 18x9F, 19x10R
http://www.seriouswheels.com/cars/to...NISMO-350Z.htm
Old Feb 5, 2008 | 06:01 PM
Spike100's Avatar
Spike100
Nice try (attempted save?)
Look here for the Nismo parts for your Z:
http://www.nissanusa.com/nismo/
--Spike
