19x8.5 or 18x9.5 all around
Old Feb 17, 2008 | 09:40 PM
hellnightkid's Avatar
hellnightkid
Default 19x8.5 or 18x9.5 all around
I going to get a set of new rims from my friends shop.
I can either get 19x8.5f 19x9.5 rear 20 -22 or 18x9.5 all around 20offset
which is a better option>??
i read thru all the VDC problem..but i don really get it
Wt size tires are best for those 2 set up. thanks alot
Old Feb 17, 2008 | 11:08 PM
ke0ki2k's Avatar
ke0ki2k
18x9.5's ftmfw...iunno. if youre wantin to look pretty fly for a white guy do the 19's. if you want fat grippz and light weight go with the 18's. I dont believe in VDC or TCS obviously though....cant help ya there.
Old Feb 18, 2008 | 03:53 AM
Lawn Dart's Avatar
Lawn Dart
I've got 18x9.5 +22 on all four corners. I've got Falken Azenis RT-615 245/40 on the front and 255/40 on the rear. It looks and handles phenomenal!
Old Feb 18, 2008 | 05:57 AM
first350's Avatar
first350
the 9.5" is key to fitting decent sized tires...
18X9.5 +20 is a perfect size and offset for flush wheels on the Z...you can run a 275 rear and 265 front w/out rubbing (not sure about VDC - I always turn mine off, so it's never an issue )
Old Feb 18, 2008 | 05:59 AM
BloMyS14's Avatar
BloMyS14
I run 18x9.5 +12 with no VDC issues.
Old Feb 18, 2008 | 06:05 AM
Neither is better than the other. Take your pick.
Old Feb 18, 2008 | 07:52 AM
Justin07Z's Avatar
Justin07Z
Nice set-up there. Good lookin Z too.
To the OP: *** 19's, get the non staggered 18x9.5's. Save weight.
Old Feb 18, 2008 | 09:57 AM
hellnightkid
then i think i will go with 18x9.5 then 245 40, 255 40
Thanks for the comment
any more suggestions?
Old Feb 18, 2008 | 10:07 AM
redlude97's Avatar
redlude97
if they can get 19x9.5 rears, why couldn't you run those all around also? Just another option
Old Feb 18, 2008 | 10:08 AM
cambo350z's Avatar
cambo350z
i got 18.9.5 +20 offset all around with 255/40 front and 275/40 rear..love the setup
Old Feb 18, 2008 | 04:54 PM
Spike100's Avatar
Spike100
^^ Looks really good!
--Spike
Old Feb 18, 2008 | 04:57 PM
Spike100's Avatar
Spike100
With 9.5" wheel width and 18" height, I would go with at least 275/40-18" on the rear.
--Spike
Old Feb 18, 2008 | 06:06 PM
hellnightkid
thx guys, but i dont really know how to get tires that work VDC,,,i read that VDC thread already.
Old Feb 18, 2008 | 06:15 PM
WSchli1672's Avatar
WSchli1672
That is an excellent looking setup. Would that be a good size to go with the Mastergrade Widebody Kit? And what rims are those? By the way to you have any VDC issues with your setup?
Thanks...
Old Feb 18, 2008 | 06:17 PM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Thanks...
No that wouldn't. Warren, give me a call we can discuss the kit.
Jim
Old Feb 18, 2008 | 06:24 PM
I doubt if I can explain it better than the VDC thread. Sorry.
Old Feb 18, 2008 | 06:30 PM
18x9.5 is the same as the NISMO wheel. What size tire? Same as the tire recommended for the NISMO wheel.
Old Feb 18, 2008 | 07:20 PM
Spike100's Avatar
Spike100
The Sticky thread about VDC gives you the information you need. Of course, anyone can become confused. The important thing is you need to keep close to the overall diameter (or saying this differently, the tire’s circumference) of the stock OEM tires.
The stock tires have these overall diameters: Front: 25.9" and Rear: 26.7"
As long as you keep close to these measurements (OD), you’re fine with VDC.
Wheel diameter has nothing to do with this since it’s the overall diameter of the tire that is important. For example: If you decide on 18” wheels:
Front 245/40-18” and Rear 275/40-18” works fine with VDC.
Or, you could go with 19” wheels and use these tire sizes:
Front 245/35-19” and Rear 275/35-19” and expect this to work with VDC.
You should also be aware that tire width has nothing to do with VDC operation. A wide tire or a narrow tire will work as long as the overall diameter of the tire matches Nissan’s circumference (a direct relation to overall diameter) specifications.
I suspect you are confused by the metric system for tire measurements, so here some additional information.
The metric tire sizing system represents a tire size as:
[section width (mm)] / [aspect ratio] - [rim diameter (inches)]
For example: a tire size 225/45-18 is 225mm wide, has an aspect ratio of 45 and fits an 18" rim (wheel).
The aspect ratio (the second number) is not a measurement. The aspect ratio represents the tire's sidewall height as a percentage of the tires width (section height divided by section width). In the example above, the sidewall height is 101mm (101/225=45).
The aspect ratio is important since that (along with the wheel size) determines the overall diameter of the tire allowing you to match your stock overall tire height (diameter). For example, a 225/45-18 tire's sidewall height is 101mm, and a 245/40-18 tire's sidewall height is 98mm. So, both tires have nearly the same overall diameter.
If you are still confused, I would suggest buying from one of the great Sponsors on my350z.com. Our Sponsors are expert in wheel/tire configurations, understand the Z, and provide perfect solutions that match your requirements.
Hope this is helpful,
--Spike
Old Feb 19, 2008 | 04:05 AM
hellnightkid
--Spike
Thanks so much. what a detail information!.
Old Feb 19, 2008 | 07:16 AM
cambo350z's Avatar
cambo350z
Thanks...
they're rota p45R's in hyperblack..no vdc issues..diameter is closest to stock as can be.
