Wheel Spacer Newb
Old Feb 22, 2008 | 08:19 AM
_Fayte_'s Avatar
_Fayte_
Default Wheel Spacer Newb
Hi, I currently have stock 07 Z with the stock 18" wheels. I want to get wheel spacers so my car can look flush. However, I have a few questions before getting one.
1. Do I have to consider how many bolts it has so that it matches my current bolt pattern on the wheel?
2. What is the recommended wheel spacer to look most flush with stock wheels?
3. If I go aftermarket wheels later on, and I already have spacers that made the stocks flush, would the aftermarket wheels be too flush?
4. Would I need to fender roll if I get spacers for stok 18" wheels OR aftermarket wheels? What determines if I need a fender roll?
Gracias
Old Feb 22, 2008 | 08:30 AM
Alberto's Avatar
Alberto
Cranky FI Owner
#1 Are you serious? Of course a 4 bolt spacer would work
#2 Id say 15-20mm
#3 If you go aftermarket and do it correctly, you wouldnt need spacers
#4 How crazy you go determines on if you need a roll or not. Some research can yield you pics, and more info.
Old Feb 22, 2008 | 09:46 AM
Contact one of our sponsers and order spacers. They will sell you an appropriate set-up for your car. Your questions show that you are completely clueless.
Old Feb 22, 2008 | 10:33 AM
Rekinyze's Avatar
Rekinyze
I tried to install 20mm spacers in the back but couldnt get the longer studs in. There wasn't enough room to get them in.
Old Feb 22, 2008 | 03:58 PM
cambo350z's Avatar
cambo350z
get eibach spacers..get 20mm front and 25mm rear. get the ones with the studs already on them..i had them on my car and they were great..then i got aftermarket wider rims and then sold them..u can get them from mynismo.com..make sure u get the type 4 which is the type that has the studs already attached...part # will end in 4.
Old Feb 22, 2008 | 04:18 PM
Ruthless18x's Avatar
Ruthless18x
+10000
Old Mar 2, 2008 | 10:09 PM
_Fayte_'s Avatar
_Fayte_
1 question for clarification: Any 20mm & 25mm will work on 07 stock wheels right?
Old Mar 2, 2008 | 10:22 PM
Boba's Avatar
Boba
Does anyone know what brand these 25mm spacers are?
http://i91.photobucket.com/albums/k3...m/IMG_0054.jpg
http://i91.photobucket.com/albums/k3...m/IMG_0055.jpg
Old Mar 3, 2008 | 05:15 AM
tree_fitty's Avatar
tree_fitty
nevermind... :|
Old Mar 3, 2008 | 07:24 AM
z-u-later's Avatar
z-u-later
No . . . if you do some research in this forum, you will find your answers. There are dozens & dozens of threads asking the very same questions on spacers.
Old Mar 3, 2008 | 05:46 PM
_Fayte_'s Avatar
_Fayte_
I searched and sort of found the answer. I see there are specs on the spacers like 5x114.3 etc... How do I know which spec will fit the stock 07 18" wheels, if going 25 front & rear?
Also, what should I look for in quality wheel spacers? Ebay vs Eibach for ex, I can't tell the cons.
Obadabot
Jun 18, 2023 11:31 PM
