Has anyone fit a 325mm wide tire on stock body Z?
Old Feb 26, 2008 | 07:58 AM
roncfpz's Avatar
roncfpz
Question Has anyone fit a 325mm wide tire on stock body Z?
I currently run 305mm wide tires on 11" wheels. It looks like there is room for another 10mm on each side (inner and outer fender). I'm wondering if anyone else has run this width without going widebody.
I'd like to go 325 but just not sure. My fenders are cut so there is a little more room. Any help would be appreciated.
Thanks,
Ron
Old Feb 26, 2008 | 08:42 AM
Chebosto's Avatar
Chebosto
tryin' to compete with your 997 turbo?
Old Feb 26, 2008 | 10:34 AM
roncfpz's Avatar
roncfpz
Probably not that far from the truth.
Old Feb 26, 2008 | 10:38 AM
ke0ki2k's Avatar
ke0ki2k
It'd look pretty wild. try it and see.
Old Feb 26, 2008 | 11:00 AM
SpeedRcr's Avatar
SpeedRcr
i dont see why you couldnt, ive seen a few 305's on the rear of a z and a g
Old Feb 26, 2008 | 11:03 AM
usmanasif's Avatar
usmanasif
There are at least a couple of members here with 325 rears. If your wheel itself allows that much rubber, then based on your clearance I don't see why not.
Old Feb 26, 2008 | 11:43 AM
Zridder19's Avatar
Zridder19
I believe Zexy has 315's on an 11" wheel stock body, might want to PM him for some further info.
Old Feb 26, 2008 | 03:23 PM
Moroccan_Mole's Avatar
Moroccan_Mole
you would really need a larger wheel 12"-13" wide to run a 325 safely, but i bet you could make it fit.
Old Feb 26, 2008 | 04:12 PM
first350's Avatar
first350
from my measurements it can't be done w/ un-modified fenders...but since yours are cut, it'll be close.
*I'm running a 295/35/18 on a 18X10+38...I've messed w/ spacers and know that if I want to run a 315/18, I'll need to roll my fenders a bit. (I also have JIC coilovers, and their struts are slightly larger diameter than OE).
Old Feb 26, 2008 | 05:09 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I know Philthy runs a 315 on an 18" wheel at the rear of his stock body G. So a 315 is definitely possible. But I haven't seen or heard of anything wider than a 315 tire without a widebody kit.
I recently got 19x11 with 305/30-19 at the rear of my G and love it.
Old Feb 26, 2008 | 05:16 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
+1
Ran 315 with a base ball bat roll with stock body on 18"
ROn please try it!! I want to know if it can be done.
Old Feb 26, 2008 | 07:20 PM
Kwame's Avatar
Kwame
The question really does not have an answer unless you specify what exact tire you are looking to run as not all 325s are the same size.
Old Feb 27, 2008 | 11:10 AM
roncfpz's Avatar
roncfpz
It was either a Pirelli (12.8" wide) or PS2 (12.9").
Old Feb 27, 2008 | 01:00 PM
BrianLG35C's Avatar
BrianLG35C
Ron,
I bet you could run 315/25/20 T1Rs on your 11s. I'm running 295/30/20s on my 10s and I'm barely rubbing. I haven't rolled my fenders yet. Obviously, it depends on your offset.
Old Feb 27, 2008 | 11:12 PM
Chad68's Avatar
Chad68
There ain't no way they will fit, without complete roll and fender pulled quite a bit and even then I doubt it. If I thought it was possible to run 325/30/19's on a 11.5-12" wheel, I would have done it. just with my 305 on 10.5" wheels I rubbed both the fender and shock sleeve at the same time (sleeve under hard compression and just barely). All with a 35 offset. Also just barely hit the fender with a 1.5" rear drop.
I have about 3/4" of room until the outer edge of my wheel (not the tire) would be completly flush with the outside of the fender and 3/4" clearance to the shock, not the sleave. that's with no load on the suspension.
If you had the fenders totally rolled and cut as far as possible, I don't see how you could run a rim wider than 11.5" and that's with the offset nailed down to the exact mm. This is probably why nobody runs a 325 on the stock body. If you could fit a 11.5"-12" rim, you would have to stretch the crap out of the tires.
you could always go ghetto and let them stick out passed the fender like an SUV, which I have seen some Z guys do in here. Why I have no idea.
If somehow you can pull it off, would love to see pics.
416blueZ
Jun 11, 2024 10:56 AM
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
416blueZ
Sep 24, 2015 02:11 PM
