Another .. "will these tires work?" thread.
Old Mar 2, 2008 | 03:32 AM
Car vs. Driver's Avatar
Car vs. Driver
Default Another .. "will these tires work?" thread.
Want to move my 245/45-18's up front and put 265/40-18's out back on stock wheels from a 2004 Performance model? The size variations are within the 3.0% rule for the VDC - but will the 265's fit on the rear wheels?
Old Mar 2, 2008 | 04:30 AM
Spike100's Avatar
Spike100
You’re pushing the 3% rule with that setup since you are increasing the front by 2.7% and decreasing the rear by 1.3%. Your Perfomance model has VDC so I would avoid going taller in the front and shorter in the rear.
Plus, 265mm is past the specification for an 8” wide wheel. You can get it on the wheel, but it will bulge a little and the tire shop may be concerned about liability.
Consider buying 245/40-18” for the front and leaving your 245/45-18 tires on the rear.
--Spike
Old Mar 2, 2008 | 05:25 AM
Car vs. Driver
I'm assuming the wider tire up front will provide more neutral handling? What about initial turn in response with that setup?
Old Mar 2, 2008 | 06:22 AM
Spike100's Avatar
Spike100
Turn-in is excellent.
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Paul.
Oct 16, 2015 07:34 PM
Shane86
Sep 17, 2015 05:33 PM
