Vibration/Ticking noise when VDC Kicks In
Old Mar 15, 2008 | 08:09 PM
EvanV's Avatar
EvanV
Default Vibration/Ticking noise when VDC Kicks In
Hey guys,
Thought I would post this up and see if anyone else has encountered this issue. I tried searching through the forum with a similar problem, but have only found a constant noise problem from the stabilizer bar. My particular noise, or vibration only comes from when the VDC kicks in (the SLIP light is on) and behind me to the right, I can hear a loud vibration/ticking noise. Once the SLIP light goes off, the ticking/vibration stops. The car is an '06 Touring M/T. When I take off the VDC, and slide around in the snow, I hear nothing. I only started noticing the noise in the last few weeks. Is this normal sign that the VDC is operating correctly, or should I get it checked out?
Thanks.
Old Mar 15, 2008 | 08:21 PM
iceagetlc's Avatar
iceagetlc
I've only ever heard a hissing noise, the same as when ABS kicks in, but not really a vibration.
Old Mar 15, 2008 | 08:23 PM
Spork's Avatar
Spork
It's probably just sounds of it working. Probably nothing to worry about if everything is working in good order.
Old Mar 15, 2008 | 09:34 PM
evolved326's Avatar
evolved326
mine sounds excatly the same way. I think its normal.
I get it all the time going up steep driveways. It does it more now after the Hotchkis swaybars.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
