Oainting hubs or whatever thats called
OK the piece that holds the wheels (not sure what its called) is turing brown. Would I be able to get some high temperature paint like rust-oleum and paint it black or would it just peel off?
you are confusing terms... or parts
the brake rotor sits between the hub and the rim. so you bolt the rim to the rotor. the section the studs (what you put the lug nuts on) stick through from the hub is called the rotor hat.
Originally Posted by THe Emperor
Are you sure 1,000,000 is high enough?
Originally Posted by 350ZTheStandard
One could only hope so because, the odds of finding 2,000,000 grit in the local Home Depot will be impossible to find. Maybe he could just double up on the 1,000,000 with 2 pieces to get the same as 2,000,000 grit......sounds logical.
Brilliant!!!
CrowzRSA
Sep 21, 2015 04:00 PM
