What's considered safe?
Old Apr 27, 2008 | 06:56 AM
jcleary47's Avatar
jcleary47
Default What's considered safe?
I do some driving on the highway here and there, and every couple of months I drive down to Connecticut to visit family which is about 3 hours on the highway.
I've seen some posts here and there that mention blowouts and tires falling off, so I wanted to check because you guys seem knowledgeable enough that you might be able to give me some advice on what tire sizes would be safe.
I am planning on going with:
18x8.5 Front
18x9.5 Rear
255/35/18 Front
275/35/18 Rear
Would this be considered safe for highway speeds? Naturally, I want it to look good, but I also don't want to have to worry about my tire coming off or blowing out or something of that nature.
Old Apr 27, 2008 | 07:05 AM
DavesZ#3's Avatar
DavesZ#3
Tire sizes wouldn't have anything to do with the potential for a blowout - something that's rare anyway. If you buy a reputable name brand tire and maintain it properly (correct pressure, periodic inspections) you should be able to drive it for years without any chance of a blowout or other failure.
Old Apr 27, 2008 | 07:06 AM
savvy's Avatar
savvy
I would just get something like a Toyo T1R, it's speed rated for faster than you should be going anyways and is a relatively inexpensive tire for decent performance.
Old Apr 27, 2008 | 07:15 AM
PDX_Racer's Avatar
PDX_Racer
+1
The only time that we've had a blowout on any car was when my wife let her car's tire pressures get too low, then she hit a good-sized bump. Instant blowout.
I make sure that all the tires are checked on a weekly basis (on the Z it's easy -- just change to the tire pressure display).
Old Apr 27, 2008 | 08:02 AM
jcleary47's Avatar
jcleary47
Good to know, thanks guys.
Old Apr 27, 2008 | 09:51 AM
Kinraze's Avatar
Kinraze
The tires will be safe, but I would consider a 40 profile on your tire vs 35 on 18s, unless you plan on dropping your car quite a bit.
Old Apr 27, 2008 | 11:40 AM
If you buy tires with the proper speed rating you will be fine.
I think what you are referring to is the "stretched look:" members will put, say, a 245 mm tire on a 9.5 inch wheel because it looks cool. Personally I do not want to be in the car if the tires fails at 80 MPH. But that's just me.
Old Apr 27, 2008 | 12:19 PM
Spike100's Avatar
Spike100
An aspect ratio of 40 would be better.
In fact the 255/35-18” front is too short if the car is VDC-equipped.
--Spike
Old Apr 27, 2008 | 02:14 PM
jcleary47's Avatar
jcleary47
So you think 255/40 front and 275/40 rear would look better? I'm open to suggestions as I still am not 100% on what to go with.
Old Apr 27, 2008 | 02:24 PM
Spike100's Avatar
Spike100
^^ Yes.
--Spike
________________
Edit: More importantly than looking better, the 40 aspect ratio tires will work much better.
Old Apr 27, 2008 | 03:16 PM
Chad68's Avatar
Chad68
245/40/18 and 275/40/18's would be a better fit for those wheels.
bcoffee20
Nov 19, 2015 06:39 PM
Alexreyes
Sep 30, 2015 11:30 PM
FromGtoZ
Sep 20, 2015 03:41 PM
