For those who run improper offsets.
Old Jul 9, 2003 | 08:06 AM
Blue Liquid's Avatar
Blue Liquid
Default For those who run improper offsets.
Do any of you notice any deleterious effects from running improper offsets? I am under the impression that wheel bearing life is compromised and the steering/suspension geometry is negatively affected. Can anyone with knowledge in this area confirm? I am asking because I have narrowed my wheel choice down to two wheels; 17 inch TE-37's or 17 inch SSR Comp H wheels from Tirerack. However, I am concerned about the discrepancy between the offsets of the 8.5 inch wide wheels from both brands. The 17x8.5 Volk is +30, while the 17x8.5 SSR Comp H is +31. Do you know if this will be detrimental to the life
of my stering, suspension and/or wheel bearing life?
Thanks.
Old Jul 9, 2003 | 09:14 AM
sdpearso's Avatar
sdpearso
1mm is not enough to affect any of these issues.
Old Jul 9, 2003 | 09:28 AM
G35 SAGE's Avatar
G35 SAGE
To preserve bearing life from what I understand you want to run near stock offset and those are so you will be fine. The suspension geometry should not be affected if you're runnign the right size tire.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
