Fixing that annoying TPMS Light on Dash.
Old May 12, 2008 | 11:59 AM
chinny's Avatar
chinny
Default Fixing that annoying TPMS Light on Dash.
Well the wheels i bought are the RH R7's and the stock sensors were not able to be put on due to the wheel design. So i roll around with the light on all the time. I know there is a way to turn this off, there has to be a fuse that you can probably pull out and maybe it would turn off. Does any one know what fuse this is, has it been done before? Is there a wiring diagram for the dash lights that i can have access to so i can try to do this and let you guys know the outcome? Thanks alot guys!
Old May 12, 2008 | 03:50 PM
DavesZ#3's Avatar
DavesZ#3
No, there is no way to turn it off.
https://my350z.com/forum/wheels-and-tires/272900-read-this-before-you-ask-about-tire-pressure-monitor-tp.html
Old May 12, 2008 | 03:56 PM
haeshik's Avatar
haeshik
Thread close
Old May 12, 2008 | 04:53 PM
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
Sorry for posting a link to another forum but someone did a writeup on a tacoma forum awhile back. Simple and effective
http://www.tacomaworld.com/forum/tec...ensor-diy.html
-Dan
Old May 12, 2008 | 05:18 PM
DavesZ#3's Avatar
DavesZ#3
Interesting concept but totally useless in this case. The Nissan sensors have a centrifugal switch that cause them to turn on and transmit only when the wheel is rotating - that helps save battery life. You can't trick them into working by pressurizing them or doing much of anything else except spinning them in a circle. That might be a little dangerous in the back of the car.
Old May 12, 2008 | 05:47 PM
Mazinger Z's Avatar
Mazinger Z
Ahah... i dunno why but that made me LOL picturing someone spinning that PVC pipe thing while they're driving. Damn TPS reports...sensors!
To the OP: Not sure about RH wheels but for Volk multi pc wheels you can "band" your TPS to your rims when you swap tires. Shouldn't be a hard mod to do. Most single piece wheels you can swap TPS's.
Old May 12, 2008 | 06:50 PM
helldorado's Avatar
helldorado
I was going to try the pressurized PVC pipe until I found out the Nissan ones were battery savers. The pressurized container isn't dangerous though. If it developed a leak, the air would just rush out the hole, it wouldn't explode or pop like a balloon.
Old May 12, 2008 | 07:04 PM
WheelDude.com
d'oh I forgot the Nissan sensors have a switch to turn them on
Old May 12, 2008 | 08:09 PM
phooka's Avatar
phooka
ignore the light!
Old May 12, 2008 | 08:21 PM
Chad68's Avatar
Chad68
You could always pull out the dash and rip out the offending LED.
Old May 14, 2008 | 07:11 PM
chinny's Avatar
chinny
^^ No lol, that would be scary. I know i pulled out a fuse for the IS250 i had, also for a charger.
Old May 14, 2008 | 07:14 PM
surfcity40's Avatar
surfcity40
turn the car off after ____ miles and turn it back on and drive ____ miles.
j/k
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
