will i have to roll the fenders?
Old May 13, 2008 | 03:48 PM
rr_z33's Avatar
rr_z33
Default will i have to roll the fenders?
i was thinking of getting some Work Meisters off of a 240sx
the specs on the wheels are..
Front: 18x9 +10
Rear: 18x10 +5
will i need to roll the fenders?
oh yeah and if it is important im on 03 stock suspension
Old May 13, 2008 | 04:48 PM
badkarma85's Avatar
badkarma85
Yes you will have to roll the fenders.
Old May 15, 2008 | 02:10 AM
SMB350Z's Avatar
SMB350Z
you might be able to get away with +19 front, and +17 rear without rolling fenders
Old May 15, 2008 | 04:57 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
with those offsets yes you have to roll
Old May 15, 2008 | 08:35 AM
finalforce's Avatar
finalforce
Don't roll.....its messy, risky, and cheap work IMO. Do it the best way, have your fenders get a custom clean cut
Old May 15, 2008 | 06:29 PM
AVmagneticZ's Avatar
AVmagneticZ
if your at stock height you wont rub...but if your dropping it i suggest rolling fenders so u can keep your rear camber at spec
**depending on drop. 1" you'll be good lower need more neg camber. but thats a fairly common size. you should be fine im running +12 on a 10.5 wheel in the rear. and im dropped 1.2" in the back. havent touched my camber but i have my fenders rolled. and im good.
also fender rolling is a common thing. if u get it done right no worries. and you cant see anything on the outside of the car after. you wouldnt be able to tell if its done unless you touch it underneath with ur hand.
Old May 16, 2008 | 11:37 AM
AFKGuy's Avatar
AFKGuy
OP i hope you don't mind if i ask here for some help.
Anyone know if i would rub on these specs?
19x10.0 +30
19x11.0 +25
Toyo T1R
255/35/19
275/35/19
I'm lowered on Tanabe NF210 (1.2" F & R)....
Old May 16, 2008 | 12:01 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
19x10.0 +30
19x11.0 +25
Toyo T1R
255/35/19
275/35/19
I think you'll be fine but it's REALLY close - it's like borderline having to roll your fenders
Old May 16, 2008 | 12:11 PM
AVmagneticZ
19x10.0 +30
19x11.0 +25
Toyo T1R
255/35/19
275/35/19
thats basically my setup it will be real close but you'll probably need to roll them. its no big deal and you cant tell from the outside....just get it done proper
Old May 17, 2008 | 12:54 AM
AFKGuy's Avatar
AFKGuy
^Thanks for the help guys.
AVmagneticZ, did you have any problem on the front at 19x10 +30? I guess i'm going to put back my stock springs for now until i found someone local that can do it. I shouldn't have any problems on stock height running those widths and offset right? I just wanna make sure
Old May 17, 2008 | 07:25 AM
AVmagneticZ
well i am 9.5 and +12 in the front so no i didnt but since u have a wider tire i dont know how that will be rubbing on the inside while turning, cause mine cuts it close. but at stock height without ur fenders rolled you might rubb since there might not be enuf neg camber and that half inch lip will help alot once rolled
Old Jul 23, 2008 | 01:34 PM
keithhofmann's Avatar
keithhofmann
why not just wait, keep your stock rims for now bc they look nicer anyway and get nicer looking wheels later on?
Old Jul 23, 2008 | 02:38 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default True...
I got away with it...but dropping on the Nismo s-tune this weekend.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
