Another Will these fit question!
Originally Posted by REV_UP_06
LAST QUESTION I PROMISE!!
I used the offset calculator and my current offset for my stock 18x8 are +33. The new rims will be 18x9.5 with +25 offset. Now I'm worried that they will not fit over my calipers because it's says my inner clearence will be 11MM LESS but the outer position will extend an extra 27mm. I don't get this offset stuff yet. So will I be ok with the rear caliper and not with the fender?
The disk type will be what mainly affects your brake clearance. Low disk types will have less clearance, High disk types will have more clearance
Originally Posted by Zivman
Come down to my shop. I will swap out spacers and you can see for yourself how noticable even a 5mm difference in offset is, let a lone a 10mm difference in offsets.
What do you do in your shop?
Is it a commercial operation?
I'm asking because I am interested and I am in your area (I'm in Edina, MN)
--Spike
