front wheel spacer problems
Old May 23, 2008 | 09:02 AM
Dealsgap's Avatar
Dealsgap
Default front wheel spacer problems
OK guys go easy. I'm relaying a question to a friend who is currently trying to put 20mm spacers on his 07 touring. He dosen't have internet access so I'm having to ask this without actually seeing what the problem is. He is saying that there is some thing on the front hub that is keeping the spacer from going on flush. It sticks out about 1 inch. It gots a 12mm bolt to it that prevents the spacer from sitting flush against the hub. Not sure what purpose it serves or if he takes it off he want be able to put it back on if he puts the spacer on..help..
Old May 23, 2008 | 09:08 AM
cheshirecat79's Avatar
cheshirecat79
Yes, it's a little bolt that's there to keep uninformed people from rotating the staggered tires. Use a socket and unscrew it, there's no harm. It can screw back on if you take the spacer off later, but I'm not sure why you could do that anyway.
You could have gotten faster results searching, good luck.
Old May 23, 2008 | 09:09 AM
JasonZ-YA's Avatar
JasonZ-YA
yup..just remove it.. and press on.......
- J
Old May 23, 2008 | 09:16 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Old May 23, 2008 | 09:22 AM
blaukal's Avatar
blaukal
your friend's owner's manual also reveals the purpose of the mysterious "bolt":
(see page 8-37 of the 2006 manual, 8-34 of the 2004 manual, etc.):
CHANGING WHEELS AND TIRES
Tire rotation
Tires cannot be rotated in this vehicle, as
front tires are different size from rear tires
and the direction of wheel rotation is fixed
in each tire.
A pin is on the front brake rotor to prevent
the rear wheels from being installed in
place of the front wheels. The spare tire
can be installed in place of the front and
rear wheels. When installing the spare
tire in the front wheel, the hole in the
spare tire wheel must be aligned with the
pin on the brake rotor.
Old May 23, 2008 | 09:24 AM
Dealsgap's Avatar
Dealsgap
Default Ask the pro's
Thanks guys I would have searched but just didn't have time..I'm getting my 08 in a couple of weeks and am planning on putting spacers on it also..I'm hoping my friend will help me since he will be a pro after putting his on...
Going to post pictures afterwards, thanks again guys..
seagrasser
Oct 11, 2015 03:27 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
Beater350z
Sep 9, 2015 03:36 PM
