Fitment question
I try my best not to ask these type of questions and try searching but here goes. Can I run a 275/30/19 on a 9'' rim on my front? Offset will be +26. I know alot use 275 on 10'' rims but can it work on a 9'' rim? Also no VCD.
Thanks
Thanks
As terrasmak says, that size tire (275/30-19”) is fine on the front with a 9” wide wheel that has a 26 offset. In fact, it will work well with cars equipped with VDC.
The only problem you have with this wide a tire in the front is “bump-steer” at higher speed on uneven roadways. You will be fine at lower speed in town, and smooth roadways at high speed.
But, running this wide a tire (i.e., 275mm) on the front at higher speeds on expressways with “truck-dish” can be a little tricky. The wider front tire in this environment “grabs” at the irregular surface and keeps you “busy” keeping the car on-line. It’s a lot of work and one reason a more-narrow front tire makes sense depending upon the circumstances.
--Spike
--Spike
Last edited by Spike100; Jun 9, 2008 at 07:14 PM. Reason: To state that the comments apply to front tires.
