Help me with my spacer purchase please..
Old Jun 11, 2008 | 05:36 PM
ekidd's Avatar
ekidd
Default Help me with my spacer purchase please..
So im about to buy some 15mm h&r wheels spacers and i had a quick question if they would be fine to run or not for my situation. Im dropped on tanabe nf210's (1.2" drop all around) and im rolling on 19x9.5 19x10.5 +22 all around w/ 255/35 and 275/35's. My question is, do you think ill be fine running 15mm spacers all around with my rears rolled? Is there anyone running this setup? I wont be using anything to adjust my camber, so will this work? thanks in advance..
Old Jun 11, 2008 | 05:40 PM
OffsetZ33's Avatar
OffsetZ33
I think that is what SIN3 is running on his TAs - he posted up some pics somewheres...
Old Jun 11, 2008 | 05:41 PM
moforeynolds's Avatar
moforeynolds
+22 on a 10.5 wide wheel is pretty damn flush at OEM camber specs; reason for wanting 15mm spacers? Not being smartass, just curious.
Old Jun 11, 2008 | 07:17 PM
ekidd's Avatar
ekidd
it looks weak in my opinion. Maybe its just because i have that taste for an aggressive looking fitment. I originally wanted 10mm spacers all around, but from what i was told, i need to have extended studs installed into my hubs because 10mm spacers dont come with built in studs because they are thin. Will i be fine with my stock studs and 10mm spacers? Meaning, will the lug nut even be able to rotate at least 10 times with 10mm spacers on stuck studs??
Justin100
Nov 25, 2021 06:26 AM
Mattg350z
Oct 2, 2015 06:51 AM
350z82
Oct 1, 2015 06:25 PM
