Can I fit 5zigen Fn01r-c 17x10?
Old Jun 13, 2008 | 05:09 PM
orangeflash's Avatar
orangeflash
Default Can I fit 5zigen Fn01r-c 17x10?
hey guys, ive done a ton of searching and it seems i get some mixed answers about the fitment of these wheels. I really like the look and width of the 17x10 fn01r-c's, and i plan on running a square setup of 17x10 all around with 275/40 tires. I still have stock suspension besides some sways. Will this setup be a problem, or should i just play it safe and go with 17x9 front, 17x10 rear, or 17x9 all around?
Old Jun 13, 2008 | 05:44 PM
THe Emperor's Avatar
THe Emperor
17x10 wouldn't be a problem but it depends on the offset.
Old Jun 13, 2008 | 05:59 PM
orangeflash
what offset should i run?
Old Jun 13, 2008 | 06:08 PM
THe Emperor
I would say around +30 up front and low 20s on the rear if you go 17x10 all around. You may be able to go alittle lower than +30 up front, depends on how agressive you want it to look.
Old Jun 13, 2008 | 06:13 PM
THe Emperor
I just looked up the rims. You should just go +25 all around. The other options are +35 which would be tucked in and +12 which may stick out too far depending on your tire width. I would just do +25 all four corners.
Old Jun 14, 2008 | 08:22 AM
orangeflash
Thank you emperor.... I ended up just getting
5zigen Fn01r-c Hot version Matt Black (new verson)
17x9 +35, 17x10 +25
Falken Fk452
265/40, 275/40
Thanx for the input and info...
Old Jun 14, 2008 | 11:28 AM
MyV6IsFast3r's Avatar
MyV6IsFast3r
May want to get some 15 spacers for the front, with only a 9" wheel the 35 is going to look terrible. +20 up front with the 9" should look much better.
Also if your running a 265 with a 9" wheel you can even go 20mm spacer and make your offset +15 and you'll have no problems.
If it were me I would go 20mm spacers up front and 5 in the rear.
Im running 9.5" front and 10.5" rear with a +15 all around and have had 265 up front and im lowered with no problem what so ever, rear I had to roll the fenders, but im also running a 295 out back... your 275 with a 5mm spacer to make it +20 out back you wont have to roll and will look damn good IMO.
Old Jun 14, 2008 | 11:06 PM
THe Emperor
+1 that +35 on a 9'' rim is gonna be alittle too tucked in.
Old Jun 15, 2008 | 12:36 AM
terrasmak's Avatar
17x10 +25 is perfect all around, but since you got the 9's just order a set of 10 to 15mm spacers if you care about looks enought for the track.
Old Jun 15, 2008 | 01:40 AM
orangeflash
so if i get 10mm spacers that means i probably need longer studs???
By the way, thanks for the input guys... im a newb at all this wheel stuff.
Old Jun 15, 2008 | 02:54 PM
terrasmak's Avatar
Ichiba spacers come with the studs.
Old Jun 15, 2008 | 05:24 PM
orangeflash
what if i did, 15mm spacer for the front and a 3mm spacer for the back... Do you guys think this would look/function ok? Would i need new studs if i used 3mm spacers or could i get away with the stock ones?
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
