Will these sizes fit my NISMO 18x9 and 19x10 wheels without rubbing?
Old Jun 26, 2008 | 01:11 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Default Will these sizes fit my NISMO 18x9 and 19x10 wheels without rubbing?
I need to know. I am going to get some tires very soon, mine are close to gone. Here are the sizes that look for a best match.
Front stock size is 245x40x18
Rear stock size is 265x35x19
Size considering front: 275x35x18 Difference between stock and new is .5% too fast
Size considering rear: 295x30x19 Difference between stock and new is 1.3% to fast
Will this look funny? Or should I try and get 295x35 in the rear 2.1% too slow? I want to get the widest possible on my stock NISMO wheels. And can I fit this without spacers? Does anyone know for sure? If I need spacers what size?
Thanks!
Old Jun 26, 2008 | 02:13 PM
daytona350z's Avatar
daytona350z
if i remember correctly, nismos are 18x9 and 19x10?
if your gonna go for the widest, throw on a 275/35f and 285/35r. nismo's come with a pretty conservative rear offset, i think +30? so you should be fine. only problem is finding tires that match.
as far as spacer talk, are you refering to your fronts?
Old Jun 27, 2008 | 04:23 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
bump
Old Jun 27, 2008 | 06:03 AM
JETPILOT's Avatar
JETPILOT
I ran the 275/35/18 F and the 295/30/19 rear and it doesn't look weird at all. Why would it look weird?
What is the offset of the wheels?
Old Jun 27, 2008 | 06:05 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Not sure what the offset is off hand? Same as the GT wheels 06+. I just want to make sure there is no rubbing issues, etc.
Old Jun 27, 2008 | 06:28 AM
JETPILOT's Avatar
JETPILOT
Can't tell you without knowing the offsets.
Old Jun 27, 2008 | 09:27 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Tire: Bridgestone RE050A 245/40/18
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
Tire: Bridgestone RE050A 265/35/19
Old Jun 27, 2008 | 09:46 AM
JETPILOT's Avatar
JETPILOT
No problems with those offsets.
Old Jul 3, 2008 | 06:38 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Emergency BUMP! I need to know if 285x35x19 will fit in my rear on these stock rims with the KDW2s? They don't have 295x30 and since Discount Tire is replacing my tires for free, I want to get these tires. Please let me know. So I will have a slightly taller tire in the rear. Should I still keep 275 up front then or go down a size?
JjL
East Canada
Jun 12, 2019 03:04 AM
Tylerx7z33
Sep 21, 2015 01:43 PM
