WHEEL SPACER problem~~
Old Jul 2, 2008 | 11:24 PM
JOY678's Avatar
JOY678
Cool WHEEL SPACER problem~~
hi,guys
i wanna upgrade my OEM wheels to 4x 19x8J wheels ,which has an offset of 38.
compared to the 18' OEMs with 30 offset.
i wanna add the 25mm wheel spacer for better looks
is that the 25mm wheel spacer OK with the OEM wheel stud. or do i need the shorten ones instead??? cuz the new wheels only got a flat joining surface with only 5 holes for stud.
cheers ~~
Old Jul 3, 2008 | 03:32 AM
cheshirecat79's Avatar
cheshirecat79
The 25mm is fine. The H&R spacer is big enough that the stock studs and lugs are sunk into the spacer and do not stick out.
Old Jul 3, 2008 | 06:26 PM
terrasmak's Avatar
Just buy better wheels with the proper offset. The money you spend of wheels and spacers will easily let you buy much better wheels.
Old Jul 3, 2008 | 06:28 PM
Tubbs's Avatar
Tubbs
Old Jul 3, 2008 | 06:33 PM
JasonZ-YA's Avatar
JasonZ-YA
project kic's will also work perfect too...25mm.
Old Jul 3, 2008 | 07:18 PM
rx7/350z's Avatar
rx7/350z
with the h&r 25mm i had to cut 2mm off my factory studs. but fore some reason they fit perfect on a friends g35
Old Jul 3, 2008 | 08:16 PM
Simple solution. Buy wheels with the correct offset.
Obadabot
Jun 18, 2023 11:31 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
