What's the sidewall difference?
Old Jul 7, 2008 | 09:58 PM
terrasmak's Avatar
Originally Posted by wasiu0607
Also, is there any way to fix this, but still keep the 35 ratio? Odometer is what concerns me more (don't want to add anymore mileage to my car than it already has).
Yes , its simple. Buy 19's.
Old Jul 7, 2008 | 10:53 PM
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
Very helpful site, thanks Dave. So by switching from 225/45 to 245/35, odometer and speedometer will be 4.93% higher. And for the rear, switching from 245/45 to 275/35 will increase reading by 4.31%. Does the car take the average of these two when displaying the odometer and speedometer? Also, is there any way to fix this, but still keep the 35 ratio? Odometer is what concerns me more (don't want to add anymore mileage to my car than it already has).
Whatever size you wind up going with just make sure the rear tires are 0.7-1" taller then the fronts. This is to aviod unusual VDC/TCS behavior.
Old Jul 11, 2008 | 05:47 PM
CKY881's Avatar
CKY881
One problem i encountered while trying to calculate the sidewall height.
When I do the calculation for ex 245/40/18, I do 245 x 0.4 which results in 98 mm. But this can also apply for 245/40/19 as well... How do I calculate one just for 18", or am i doing this calculation wrong?
Old Jul 11, 2008 | 06:24 PM
Spike100's Avatar
Spike100
Obviously you want the look that you get with 35 a profile. So, do what terrasmak suggests:
Get something like this:
Front: 19x8.5” wheels with an 18 offset and 245/35-19” tires
Rear: 19x9.5” wheels with 22 offset and 275/35-19” tires
Make a decision and end this… Please. (friendly kidding here)
--Spike
Old Jul 12, 2008 | 12:54 PM
Eddie@Performance
Performance Nissan
My statement was for overall tire height, not sidewall height. If a tire is 26" tall in the front, the rear must be between 26.7-27" tall.
Old Jul 12, 2008 | 06:04 PM
CKY881's Avatar
CKY881
Thx Eddie and everyone.
One more off topic question. Is it the same width if I get 10mm spacers and 265/40R as opposed to just 275/40R? Does the difference in tire width cancel out the need for spacer, or are spacers a totally diff. ball game?
Old Jul 12, 2008 | 06:07 PM
Doesn't matter if it is a 16 or 20 inch tire. Side wall height is side wall height.
Old Jul 12, 2008 | 06:09 PM
A tire that is 265 mm wide is always 265 mm wide.
A spacer will move the position of the wheel.
Old Jul 12, 2008 | 07:34 PM
Eddie@Performance
Performance Nissan
Since the spacer has no effect on sidewall height or overall tire height it doesnt change a thing other then wheel offset.
Old Jul 14, 2008 | 06:23 PM
CKY881's Avatar
CKY881
One last question lol.
If I get 235/40 in front, which is 1% increase odometer & speedometer reading, and rear 265/40, which is 1.27% increase, does the car take the average of these two?
Old Jul 14, 2008 | 07:14 PM
Spike100's Avatar
Spike100
^^ Not sure what you mean when you say "average of these two."
But, the sizes you mention on 18" wheels are within the Z's OEM tire-size specifications, so you won't have any problem.
It's interesting that you selected the OEM tires size (Michelin PS2) that Porsche uses on some of their cars.
--Spike
Old Jul 14, 2008 | 07:35 PM
Cant tell jack. What is the wheel diameter?
Old Jul 14, 2008 | 08:05 PM
CKY881's Avatar
CKY881
--Spike
They are? I thought the Z's OEM specs for 18" are 225/45F and 245/45R.
Anyways, what I meant was from the calculator Dave gave me, it said I will have 1% increase in speedometer and odometer if I switch fronts from the OEM 225/45/18 to 235/40/18, which means at 70 mph, the actual speedometer will display 70.7 mph. I just wanted to know since my front is 1% increase and rear is 1.27% increase, will the car take the average of the two to display on the speedometer?
18" Dave
Old Jul 14, 2008 | 08:22 PM
Spike100's Avatar
Spike100
^^ No it doesn't average the two, but instead depends upon the overall diameter of the currently mounted tire.
My Porsche comment was only to point out that the tire size you ask about fit Z's perfectly, but are also a size that Porsche uses on some of their cars. It was simply an observation and nothing to do with the premises of this discussion.
--Spike
Old Jul 14, 2008 | 08:37 PM
Boba's Avatar
Boba
I guess im going to have to measure the radius of the tire and then find the diameter that way?
Old Jul 14, 2008 | 08:41 PM
18" Dave
Speedometer will read 101.27 MPH at 100.0 MPH.
Old Jul 14, 2008 | 08:56 PM
Boba's Avatar
Boba
So speed on speedometer will be based on rear tires then? Does that mean I can go as small as possible with the front tires and speedometer & odometer will still only be off by 1.27%?
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
