Tps Question
Old Jul 28, 2008 | 12:18 PM
jcrdr's Avatar
jcrdr
Thumbs up Tps Question
i know this might be a noob question, but hey, i have no shame.....ANYWAYS, my tps light is on and will not go away. i do have aftermarket wheels so i know when i usually drive for about 80 miles, itll turn on, but when i turn off car, itll go away (reset). for some reason NOW, the light will not go away, i even tried unplugging the battery.....no good! anyone have a resolution to this?? it would be much appreciated!
thanks
Old Jul 28, 2008 | 12:22 PM
SupaDoopa's Avatar
SupaDoopa
One of your valve sensors may be bad. Some places will not replace them with your new rims and you have that issue. I would take it to either the dealership or go purchase some and have them installed.
Old Jul 28, 2008 | 12:32 PM
dkmura's Avatar
dkmura
General & DIY Moderator
The TPS sensors are located inside each wheel (part of it is the valve stem). The TPS antenna in the PS A-pillar picks up the signal from each TPS and relays it. If there's no signal, it triggers the warning light. It'll keep doing this each time you start the car until you resolve the problem.
Old Jul 28, 2008 | 03:20 PM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/wheels-tire...-tps-tpms.html
Old Jul 28, 2008 | 08:00 PM
Chaser720's Avatar
Chaser720
Lemoned Z
thanks
Dont know if you missed this one but did you put the TPMS sensors in your new wheels. That might be a minor problem.
Old Jul 29, 2008 | 12:01 PM
jcrdr's Avatar
jcrdr
no, didnt bother too. i knew the light would come on every now and then if i didnt. from when i put the new wheels on until saturday......like i said, the light would come on, say if i did a long drive to vegas, but when i would turn car off, it would reset and light would turn off. now though it doesnt wanna do that anymore!!
Old Jul 29, 2008 | 12:06 PM
jcrdr's Avatar
jcrdr
thx dave! it is info though i had knew from past experience......so now THE ONLY way to fix that is to take my sensors from my stocks and put them on my new wheels??? too much hassle!!!!
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
