How wide can the front rim be?
Old Jul 31, 2008 | 03:18 PM
vbgambini's Avatar
vbgambini
Default How wide can the front rim be?
I wanted to know what is the widest after market wheel can fit on the front of the 350z with no roll or anything done to the fender? Can 10'' fit with no issues? thanks guys.
Old Jul 31, 2008 | 03:23 PM
bluesi808's Avatar
bluesi808
nope, won't fit. u will have some major fender issues. i.e. can turn the wheel all the way, it will rub while trying to turn into an inclined driveway, etc.
Old Jul 31, 2008 | 03:25 PM
marques1's Avatar
marques1
i have 9.0inch front and they rub a tad bit on a turn with a incline of some sort.
Old Jul 31, 2008 | 03:36 PM
status:one's Avatar
status:one
It all depends on your offset. Jinsei is running a 10.5" rim in the front.
Old Jul 31, 2008 | 03:47 PM
marques1's Avatar
marques1
yeah status one is correct!!
Old Jul 31, 2008 | 04:43 PM
DavesZ#3's Avatar
DavesZ#3
Offset, wheel width, tire brand and lowered all come into play.
Old Jul 31, 2008 | 05:55 PM
Nevaland90's Avatar
Nevaland90
i have 19x10+20 and no issues what so ever...and my car is slammed.
Old Jul 31, 2008 | 06:00 PM
06PPWZ's Avatar
06PPWZ
Damn look at the rear lip on that thing.
Old Jul 31, 2008 | 06:18 PM
ppw350Zunit's Avatar
ppw350Zunit
18x10 +19 (5mm spacer) +14 FRONT:
https://my350z.com/forum/media-share...ppw-advan.html
Old Jul 31, 2008 | 07:22 PM
THe Emperor's Avatar
THe Emperor
What rims are those? Thats a deep lip.
Old Jul 31, 2008 | 07:27 PM
haeshik's Avatar
haeshik
ill say it again, sick drop/wheels
Old Jul 31, 2008 | 07:34 PM
bluesi808's Avatar
bluesi808
well ok if you buy an 18" wheel and are sitting high like a 4 wheeler than fine. no wonder you don't have any rubbing issues.
i have a 20x9.5 in front and i rub fender all the time going up driveways. i guess the op had to be a bit more specific. i guess it's all about offset. but, why go so wide in the front anyway? to me it just seems like a lot of headaches.
i had 19x9.5 (carrera wheel) on a porsche boxster with stretched tires. it fit but had major issues turning and driving into driveways.
Old Jul 31, 2008 | 07:40 PM
marques1's Avatar
marques1
front: 20+9.0 offset +15
rear: 20+10.0 offset +20
my car rubs fenders on hard turns and inclines!!!
Old Jul 31, 2008 | 07:51 PM
bluesi808's Avatar
bluesi808
Default ppw350zunit
here are the pics:
from the rear:
from the front:
front driverside from up top:
rear driverside from up top:
look at your front tire. it belongs on a bippu(vip style) car. no wonder you can't drop your car. it's too wide in the front. the worst thing is that you rear tire looks like it doesn't stick out as much as the front. i don't know about running 10" in the front. don't mean to dis your car or anything, i love advans. but, i still think the op will have probs if he doesn't roll the fenders.
Old Jul 31, 2008 | 07:58 PM
marques1's Avatar
marques1
lol yeah that will rub for sure!!
Old Jul 31, 2008 | 11:14 PM
ppw350Zunit
lol....just because my car isn't "dumped" doesn't mean it's not lowered. i'm lowered on hotchkis and BTW, to this day, i have NEVER rubbed with this set-up.
short recap:
Nevaland90 - 19x10 +20 offset/tire size ?/car is slammed/NO RUBBING
ppw350Zunit - 18x10 +14 offset/265-35 tires/car is lowered .5 inch/NO RUBBING
Old Aug 1, 2008 | 12:02 AM
rickyislaZy's Avatar
rickyislaZy
Width is just only one of the factors that will determine if a wheel will fit, there is the offset, tire size, and most importantly the ride height and camber.
Old Aug 1, 2008 | 03:47 AM
asmvp84's Avatar
asmvp84
^^+1 why would you want to go with a 10 in the front anyways?? save that for the rear...your best bet is to find the same offset as someone else running a 10 in front and try to mimic the setup including drop, wheel size, offset, and maybe even a spacer to get you away from the strut tower.
Old Aug 1, 2008 | 02:04 PM
vbgambini's Avatar
vbgambini
thanks guys for all the info. Im looking to drop my car with either the Eibach Pro-Kit or Tein S-Techs. Probably S-Techs. Just wanted to know what width with maybe a 19'' Work Meister S1 or 19'' SSR SP1. Its what im thinking of doing.
Old Aug 1, 2008 | 02:56 PM
terrasmak's Avatar
I run an 18x9.5 +22 front with 255/40 , lowered with 1.5 camber no problem. I wish my wheel was available in 18x10, i have a little room on each side to go wider.
