Davidv read plz
Old Aug 3, 2008 | 05:50 PM
CKY881's Avatar
CKY881
Default Davidv read plz
Lol i thought id post here since you never reply to PMs.. Anyways, i remember in one thread, you posted a reponse to someone asking if adding spacers to their current setup would rub against fenders... You answered him and said to use something like a thick ring to measure, and keep adding until it rubs?... or something like that. Do you remember what is?
Thanks.
Old Aug 3, 2008 | 05:53 PM
06dieselZ's Avatar
06dieselZ
Hi, im DavidV's brother and we do not know what you're talking about.
Old Aug 3, 2008 | 05:55 PM
DavesZ#3's Avatar
DavesZ#3
You can use large washers to simulate a spacer. Put a few on a couple of the studs then mount the wheel.
Don't drive on it like that though, you won't have enough thread engagement on the "shorter" studs.
Old Aug 3, 2008 | 07:26 PM
I cant take credit for washer idea but it is practical. As DavesZ#3 mentioned the washers will not take the cars weight.
Old Aug 3, 2008 | 08:59 PM
CKY881's Avatar
CKY881
Oh ok.
When i want to know whether the rear fender would rub against my wheel when adding spacers, can i just stick a ruler in on top of the tire and then kind of see if the ruler is straight with the rear fender? I could also measure the space i have while im at it too so i wouldnt have to use washers.
Old Aug 4, 2008 | 03:04 AM
DavesZ#3's Avatar
DavesZ#3
Figuring out if it rubs is a little tougher than that. When the suspension compresses, the wheels travel up and in, not just straight up. So a line drawn from the face of the wheel straight up that intersects with the fender edge might be okay.
Old Aug 4, 2008 | 05:54 AM
Motormouth's Avatar
Motormouth
camber also increases as load is put on the rim so you might have more clearance than you think.
you COULD use one of those online calculator thingies... they aren't perfect but will give you an idea. or draw a template.
if the washers cannot support the weight of the car, then they are useless IMO. maybe cut out a peice of wood and drill holes for the studs? I don't know, just thinking.
Old Aug 4, 2008 | 11:53 AM
z-u-later's Avatar
z-u-later
Post pics of your current setup so we can visualize how much room you have to work with.
Old Aug 4, 2008 | 11:59 AM
haeshik's Avatar
haeshik
Old Aug 4, 2008 | 12:35 PM
CKY881's Avatar
CKY881
I have 18x9.5 +20 all around on Falken FK-452 245/40F and 275/40R. You gotta add in some mathematical calculations into the visualization as well man!
Thx!
Old Aug 4, 2008 | 12:37 PM
Motormouth's Avatar
Motormouth
that 275/40 is pretty tall isnt it?
Old Aug 4, 2008 | 02:55 PM
Boba's Avatar
Boba
nm
Old Aug 4, 2008 | 03:09 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
not really, imo it is perfect for 9.5 wide.
apex locator
Jul 23, 2021 02:27 AM
35reilly
Sep 28, 2015 07:42 AM
Tochigi_236
Sep 27, 2015 03:40 PM
