How many have gone from 17 in. wheels to 19 in. wheels
Old Jul 30, 2003 | 06:03 PM
350zroadster's Avatar
350zroadster
Default Re: Re: Re: Re: Re: Re: How many have gone from 17 in. wheels to 19 in. wheels
Originally posted by little_rod
Dude, it is not that big of deal to me, heh. There are many options that he could do. There are also many tire calculaters that will get his diameters close to stock.
From my understanding, he never mentioned getting 18s. I don't know where you got that from. Also, the speed sensors are on the back, I started a trend on it a few weeks ago. Should be able to get it in a search.
Not trying to be difficult, just accurate.
I was replying to post by mgl.
Originally posted by mgl
you got 17"s on your touring??? you should have 18"s, right??
Old Jul 30, 2003 | 06:59 PM
little_rod's Avatar
little_rod
Thats cool. mgl just didn't know that the auto touring came with 17s.
Old Jul 30, 2003 | 07:14 PM
KarmaMag's Avatar
KarmaMag
Havabooz,
Here are some more pictures for you.
Old Jul 30, 2003 | 09:57 PM
cobrasak's Avatar
cobrasak
is it me or do I not see a difference between a rolled fender and a stock one.
Hmm maybe a side by side compro
Ps I do love them C4's where'd ya get em from and how much do they run
Old Jul 30, 2003 | 10:31 PM
little_rod's Avatar
little_rod
Dude, the only difference is on the inside of the fender. The lip of the fender is curled up, which you can't really see from pics like these. So it is not just you, if you want to roll your fenders for bigger tires, its your car and it will look good either way.
Old Jul 31, 2003 | 05:03 AM
havabooz's Avatar
havabooz
karma..those 295's are lookin yummy...very clean job...but i only got 10"s in teh back so ill just be modest and stick with the 285
thanks for the pics by the way
Old Jul 31, 2003 | 10:31 PM
piser's Avatar
piser
The ride difference is actually not noticable to me. But what is noticeable is when I hit a turn. Woha, what a great difference.
Do you mind describing this difference? I'm thinking of going from 17s to 19s and I'm a little curious... It seems to me with my limited knowledge that the 19s wouldn't corner as sharply.
Old Aug 1, 2003 | 05:50 AM
havabooz's Avatar
havabooz
someone correct me if im wrong but i think when little rod siad that it feels great on turns he was reffering to the width of his new wheels
you know the sayin..wider is better
Old Aug 2, 2003 | 02:18 AM
03 Z for ME's Avatar
03 Z for ME
Default Speed sensors
Actually, the speed sensors are on the rear wheels
TRUE! That's been confirmed by all of us that DYNO. How else could the speedo read 140+ while the front wheel weren't moving at all?
Old Aug 3, 2003 | 03:35 PM
little_rod's Avatar
little_rod
Well, if you have larger rims and lower profile tires, you have less flex in a corner. When I drive, the car just feels more stable in a corner and just about anywhere. The wider tires and less sidewall flex give you more ultimate lateral G pulling ability.
As an engineer it just makes sense. The more flex you have, the better the car will ride. But in max cornering, you don't want to use your sidewalls to stick in corners, and this flex can hurt you. Now, in a dragrace and most autox, you need to be lighter to be better. But in some cases, the taller wheel can be an advantage.
Old Aug 19, 2003 | 12:54 PM
zoasis's Avatar
zoasis
would 295/35/19's fit with rolled fenders on a 19X10.5??
I guess I'll find out in a couple days!
Old Aug 19, 2003 | 01:48 PM
denic79's Avatar
denic79
I went with 19x10 in the rear with 275/35/19. I didn't know racing hart made a 19x10.5 I would of gone that way. Will 285/30/19 be o.k because i'm almost dew for rear tires.
Attached Thumbnails How many have gone from 17 in. wheels to 19 in. wheels-img_0007.jpg
Old Aug 20, 2003 | 08:22 AM
arvin's Avatar
arvin
I have 19's x 11 rear OZ Superleggera III. I also have 295x35x19 Michelin tires. I have no problems whatsoever with tires rubbing. I don't understand why people have to roll fenders with a 10.5" rear. Now, it makes me wonder if my rims are really 11' wide.
Old Aug 20, 2003 | 08:49 AM
little_rod's Avatar
little_rod
Dude, it totally depends on your offsets and individual application. If yours are fine, then don't worry about it.
Old Aug 21, 2003 | 04:02 AM
andymr1's Avatar
andymr1
Default getting the rub
Hoping one of you maybe able to advise.
Went with Volke TE-37's 19x9.5 on the rear 19x8.5 front. Out at the track and deep in some high speed corners I'm definatley getting a rub on the rears.
Anyone got any bright idea's. How do I find out more about fender rolling?
Andy R
Old Aug 21, 2003 | 09:36 AM
KarmaMag's Avatar
KarmaMag
Arvin,
What is your offset for your rear 11"? I'm running 10.5 with offset 22 and have to roll the heck out of the fender.
Andymr1,
You'll have to get your fender rolled. Called around and ask the shop around your area to see if any one of them has a fender rolling tool. It's very easy to crack the paint on the Z because there's a weld spot along the fender lip. Make sure they heat the paint real hot before they start rolling the fender.
Denic79,
Nice wheels! You might have to roll the fenders if you go with 285 depends on your offset (what is your offset, BTW?) and brand of the tires. Some tires are wider than the others eventhough they're all same spec.
Here's mine.
Old Aug 21, 2003 | 02:19 PM
denic79's Avatar
denic79
Tell you the truth i don't know what my offset is and im going with toyo t1-s's. I don't like the toyo's at all what do you recommend for my next set of tires.
Old Dec 6, 2003 | 05:50 PM
  #38
Stinger1's Avatar
Stinger1
Well, I finally did it. I just had the ADR X-Factors installed. They can be seen here:
https://my350z.com/forum/showthread....threadid=48523
Old Dec 7, 2003 | 07:23 AM
  #39
LIL RAJA's Avatar
LIL RAJA
Originally posted by KarmaMag
Havabooz,
I used to run one of the performance shop here in the Bay Area and got to learn how to roll the fender. It's pretty easy, takes about 30 mins to roll 2 rear fenders. If you want to get your fender rolled, make sure that the place have a fender rolling tools, not just a baseball bat or pipe. You also have to heat the fender with the heatgun to soften the paint so it doesn't crack.
The reason that I bought 10.5" with offset 22 and 295 tires is because I like the lip (almost 4") plus I like the fact that 295 is the widest tires you can put on a Z.
Check out the pictures below for now. I'll take some close up of the fender whan I get a chance.
Chad
amazing looking. wOw!!! is all it got to say.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
