FAQ's: Offsets, pics, Tire Calc, etc...
Old Mar 11, 2004 | 06:22 AM
Todd@ProDyno's Avatar
Todd@ProDyno
Guys...this was meant as an informative thread. I dont generally list prices, or quote in a post. PM, Email, or call for quotes. As far as pictures go..everything I have available is in our online car gallery at www.discounttiredirect.com
Old Mar 28, 2004 | 08:15 PM
bman_350Z's Avatar
bman_350Z
I just tried to put on my new rims (Volk GT-N) and there's an extra bolt on the rotor that I've never seen before. Is this the alignment pin you were talking about? Will removing the bolt cause any damage?
Old Mar 29, 2004 | 05:42 AM
cupcar's Avatar
cupcar
Why don't any wheel distributors carry BBS DTM forged magnesium wheels?
Old Mar 29, 2004 | 07:04 AM
2003z's Avatar
2003z
you can remove that bolt. Its just to keep the stock rear wheels from getting put on the front by an ignorant service tech.
Old Mar 30, 2004 | 06:30 PM
96_vqmax's Avatar
96_vqmax
Hey can someone help me with the offset and weight on the G35 coupe 18".I'm in the market of getting one,Thanx!
Old Apr 2, 2004 | 08:15 PM
GoSooners's Avatar
GoSooners
Don't know weight but sizes are 18x8.0" front and 18x8.0" rear with 30 offsets both front and rear.
Old Apr 10, 2004 | 05:57 PM
rodH's Avatar
rodH
guys, here is the offset calculator in case you need to use it
http://toy4two.home.mindspring.com/offset.html
Old Apr 15, 2004 | 05:10 AM
samlb's Avatar
samlb
Default Re: FAQ's: Offsets, pics, Tire Calc, etc...
Originally posted by DiscountTireDirect
The below offset specs are "conservative" We have acheived max fitments well beyond these specs, but below is for those of you who play it safe. When going to the edge...be sure to call to discuss it more throughly.
ALLIGNMENT PIN ON FRONT HUB CAN BE REMOVED, PIN IS
TRACK MODEL IS EQUIPPED WITH BREMBO BRAKES WHICH
LIMITS THE AMMOUNT OF
Tire Size Calculator
Good info on alignment pin--have to give that a try. I bought the following for a '03 350z Touring 6-spd
WHEELS : ENKEI RPF1 18x8.5 F / 18x9.5 R
TIRES : FALKEN GR BETA FK-451 / 245/40ZR-18 Front - 275/40ZR-18 Rear
Installed front wheels without adapter because would not fit with alignment pin. Hopefully reinstalling with spacer/adapter the came in installation kit will fix low-speed roar from front end.
Old Apr 15, 2004 | 05:12 AM
samlb's Avatar
samlb
Default Re: Re: FAQ's: Offsets, pics, Tire Calc, etc...
Question for DTD -- what is the offset on RPF1's -- see quote.
Old Apr 20, 2004 | 05:10 PM
rondiggy's Avatar
rondiggy
Question:what company makes the GGAMES and the 5Zigen rims? And what sizes they come in?
Old Apr 21, 2004 | 04:58 AM
samlb's Avatar
samlb
Default Re: Re: Re: FAQ's: Offsets, pics, Tire Calc, etc...
Offset for:
8.5x18 -- +30
9.5x18 -- +15
Old Apr 26, 2004 | 06:57 PM
azn_speedracer's Avatar
azn_speedracer
i have 18 inch volk le37t's and they are stagard 8.5 in the front and 9.5 in the back and i was wondering if 245/40ZR18 and 275/35ZR18 would fit and ride properly
Old Apr 28, 2004 | 06:13 PM
MethodRN's Avatar
MethodRN
For Sale
Sup guys. I'm fixing to get my z and wanted to know which of these wheel sizes and offsets would work on my car with out affecting tire wear and handleing too much. Thanks. These are for PIAA Super Rozza. Also considering Work Meister S2R. Any suggestions appreciated. Thanks again!
18x7.5 5x114.3 48mm (hyper black) SR875D48H $495.00
18x8 5x114.3 50mm (hyper black) SR880D50H $499.00
19x7.5 5x114.3 42mm (hyper black) SR975D42H $509.00
19x8 5x114.3 42mm (hyper black) SR980D42H $525.00
19x8 5x114.3 45mm (hyper black) SR980D45H $525.00
19x9 5x114.3 25mm (hyper black) SR990D25H $569.00
19x9 5x114.3 50mm (hyper black) SR990D50H $569.00
19x10 5x114.3 25mm (hyper black) SR9100D25H $599.00
18x7.5 5x114.3 48mm (silver) SR875D48S $495.00
18x8.0 5x114.3 50mm (silver) SR880D50S $499.00
19x7.5 5x114.3 42mm (silver) SR975D42S $509.00
19x8 5x114.3 42mm (silver) SR980D42S $525.00
19x8 5x114.3 45mm (silver) SR980D45S $525.00
19x9 5x114.3 25mm (silver) SR990D25S $569.00
19x9 5x114.3 50mm (silver) SR990D50S $569.00
19x10 5x114.3 25mm (silver) SR9100D25S $599.00
Old Apr 28, 2004 | 06:15 PM
MethodRN's Avatar
MethodRN
For Sale
PS don't want wheel larger than 19x9
Old Apr 28, 2004 | 06:20 PM
MethodRN's Avatar
MethodRN
For Sale
Sup dude. According to www.finalstageauto.com those tire sizes will work w/ z. Look up package for VOLK GT7 wheels on site.
Old Apr 29, 2004 | 06:43 AM
Todd@ProDyno
The 275-35-18 is shorter than the 245-40.
245-40-18 25.72"
275-35-18 25.58"
You want to try to maintain the stagger of the stock set up, between 1/2" & 3/4" front to rear, front obviously shorter.
Tire size calculator Tire size calculator
Old Apr 29, 2004 | 06:45 AM
Todd@ProDyno
GGames made by Rays, distributed exclusively by Discount Tire
5Zigen, made by 5Zigen...also available through us. Check out www.5zigenusa.com for styles, or www.discounttiredirect.com for what we have in stock on either brand
Old Apr 29, 2004 | 06:47 AM
  #38
Todd@ProDyno
Method. Do anywhere from a 8-9" up front. Stay low on offset, +25 or so, 245 tires usually ideal. In the rear, 9-10.5 with offsets in the +25 to +35 range. 275 to 295 rear tires.
Old Apr 30, 2004 | 03:58 PM
  #39
Jny11's Avatar
Jny11
Has anyone tried using the combonation of :
Front: 245 40 18
Rear: 275 40 18
I am having a hard time finding front stock size of 225 45 18 and someone recommended the aforementioned size. Has anyone tried it? If so, how does it compare to the stock version?
Any advise would help, thanks.
Old May 14, 2004 | 01:46 PM
  #40
LUCK's Avatar
LUCK
I really like this set.
Does anybody know the spec for this set? ( Size, Width, and Offset )
Thank you in advance.
LUCK
