FAQ's: Offsets, pics, Tire Calc, etc...
Old Jul 30, 2003 | 10:42 AM
Todd@ProDyno's Avatar
Todd@ProDyno
Default FAQ's: Offsets, pics, Tire Calc, etc...
The below offset specs are "conservative" We have acheived max fitments well beyond these specs, but below is for those of you who play it safe. When going to the edge...be sure to call to discuss it more throughly.
ALLIGNMENT PIN ON FRONT HUB CAN BE REMOVED, PIN IS
TRACK MODEL IS EQUIPPED WITH BREMBO BRAKES WHICH
LIMITS THE AMMOUNT OF WHEELS THAT WILL FIT!!!!
WIDTH OFFSET WIDTH OF TIRE
7.0 +5/+50 215/225
7.5 +11/+50 215/225/235
8.0 +18/+47 225/235/245
8.5 +24/+40 235/245
9.0 +30/+35 245
Rear Only
8.0 +7/+50 225/235
8.5 +13/+50 235/245/255
9.0 +19/+47 245/255/265
9.5 +26/+40 255/265/275
10.0 +32/+35 265/275
18 INCH WHEELS COME WITH A TIRE PRESSURE MONITOR TIRE SIZE CONNECTED TO O.E. VALVE STEM. NO LESS THAN 1/2 INCH AND NO MORE THAN 3/4 OF AN INCH HEIGHT DIFFERANCE BETWEEN FRONT AND REAR TIRE SIZE FOR ABS BRAKE SYSTEM/TRACTION CONTROL. 350Z'S WITH 18-INCH WHEELS HAVE A AIR MONITORING SYSTEM. THE SENSOR IS MOUNTED AT THE BASE OF THE VALVE STEM AIR PRESSURE SENSORS ARE A ONE PIECE UNIT AND CANNOT BE USED WITH REVERSE BARREL WHEELS
Wheel Offsets
The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic.
Positive Offset
A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
Zero Offset
When the hub mounting surface is centered within the rim, it is known as a zero offset.
Negative Offset
If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or “deep dish”.
Note that extensive negative offset can potentially cause increased steering wheel kick-back and place additional stresses on the vehicle's entire suspension.
Wheel FAQ's FAQ's
Tire Size Calculator
Old Jul 30, 2003 | 10:53 AM
Todd@ProDyno
19" GGames
19" 5Zigen Hyper 5ZR
17" 5Zigen Typhoons
18" Privat Farhen
18" Fondmetal 9X
More 18" Privats.
18" Enkei RPM2
19" & 20" Konig Appeals
Old Sep 16, 2003 | 12:30 PM
Ricky's Avatar
Ricky
Awesome, how much do th 18" Enkei RPM2 run with the cheapest tires?
Old Oct 18, 2003 | 01:17 PM
arnelr21's Avatar
arnelr21
NIce thread guys. Keep up the great work.
Old Jan 20, 2004 | 07:55 AM
cupcar's Avatar
cupcar
How about a list of wheel weights?
Old Jan 22, 2004 | 06:57 AM
350z-z33's Avatar
350z-z33
Question Different size?
Does anyone know if it's ok if I have the following tire size combination on my Track Z;
Front: 225-45-18
Rear: 255-40-18
My main concern is VDC and ABS will get mess-up! Any help appreciated!
Old Feb 5, 2004 | 01:31 PM
wick3d350Z's Avatar
wick3d350Z
will the g games mess the tire pressure monitor up?
Old Feb 6, 2004 | 06:04 AM
Todd@ProDyno
Default Re: Different size?
Front: 225-45-18
Rear: 255-40-18
those are almost identical in overall diameter. Nissan USA recommends keeping the stagger between .5 and .75 inches.
The only GGames currently available for your car are the 19's, and the sensor will not fit without the use of bands. The 18s will be here shortly, they should work...but we still need to test them
Old Feb 8, 2004 | 12:26 PM
Jax350z's Avatar
Jax350z
Question
Jax350z's Avatar
Jax350z
Question
*dbl post*
Old Feb 8, 2004 | 12:29 PM
Jax350z's Avatar
Jax350z
Question
I have best traction for 1/4mi on my mind for my z, and I also plan to get a TT in the future.
Basicly I want the widest possible rims & sticky tires that I can get on 17in wheels.
I mean really wide. I am thinking physical limits here.
I have a base model 2004 stone silver with no brembo brakes or traction control.
Also, would you have these tires available? I havn't seen what I am looking for on your site.
-Jax350z
Old Feb 8, 2004 | 12:35 PM
Jax350z's Avatar
Jax350z
Sorry about the stupid frickin triple posts... my account won't let me delete them even though it's activated
Old Feb 8, 2004 | 09:06 PM
jng1226's Avatar
jng1226
What's the story? Why no wheel weights? This is a PERFORMANCE car, and I am also interested in maintaining that performance, not DEGRADING it with heavy wheels.
Old Feb 9, 2004 | 02:27 PM
Todd@ProDyno
JAx..tis a good question. No one has wanted to explore the limits of 17" wheels. Who knows...17x10.5 with 315-35-17 may fit out back...but no one has tried. Ill try to get another Z up here to measure for 17s.
I dont have a wheel weight database for this site built yet, but...every wheel that has come in here over the past 8mos has been weighed and is in our system
Old Feb 9, 2004 | 02:36 PM
cupcar's Avatar
cupcar
Discount Tire Direct- How about a post on the range of weights lightest to heaviest in the 17, 18 and 19 inch categories that you have in your database. I think some would be surprised at how much difference there can be.
Old Feb 10, 2004 | 03:36 PM
Jax350z's Avatar
Jax350z
Thanks for the reply, I was also wondering that if 10.5's & 315/35/17's would fit in the back, then where could I find these tires and rims?
Of course weight is also a consern.
Old Feb 10, 2004 | 07:34 PM
jhbrennan's Avatar
jhbrennan
Default Larger Rear Tires
225-50/17 on front - can I go to 245-50/17 on the rear? Looks like there is 0.7 inch difference in height which looks to be about the same difference between front and rear with the stock 18" sizes. Do you foresee any problems with TCS, etc. Thanks.
Old Feb 25, 2004 | 01:23 PM
1337's Avatar
1337
can we also get the tire weights? so we can fit with the rim weights... Or is Nissmo the best for Z in this cathegory?
Old Feb 29, 2004 | 07:23 PM
kevinkatz's Avatar
kevinkatz
another 350zx website is promoting goodyear eagle F1GSD3 tires.
they recommend 255/40/18 front and 275/40/18.
does discount tire have these and what do they cost?
can discount tire post the prices fo the cool wheels shown above?
Old Mar 10, 2004 | 03:19 PM
JdM_SiN's Avatar
JdM_SiN
I was wondering if tire discount had a picture of a blue 350z with any sort of webbed weels powdercoated the same color i am very undecisive please post if you have or anyone thanks
