18x10 +42 offset. BAD OFFSET?
Old Aug 24, 2008 | 01:51 PM
Goyangyi's Avatar
Goyangyi
Default 18x10 +42 offset. BAD OFFSET?
Hey guys,
I am looking around for some wheels and found one with 18x10 +42 offset. I believe that the offset is way to high, but since I am rather new to shopping for wheels, could someone tell me how this will fit on the Z? Will this have issues of sticking out too far and fender rubbing with certain size tires?
I have already checked the offset calculator and it says that it is
Inner clearance: 37mm LESS
Outer position: EXTEND an extra 13mm
THANKS!
Old Aug 24, 2008 | 01:55 PM
Goyangyi's Avatar
Goyangyi
Made a mistake in offset calculation.
it is should be:
Inner Clearance: 34mm LESS
Outer position: EXTEND an extra 16mm
Old Aug 24, 2008 | 02:02 PM
asmvp84's Avatar
asmvp84
offset is way to much you were right...that isn't a Z kind of wheel with a 10" tire anything with a +20 offset is where you want to be...take some time and search to find a setup you like that someone is running and mimic it
Old Aug 24, 2008 | 02:15 PM
Goyangyi's Avatar
Goyangyi
Thanks for the response.
This spec is for the rear wheels, but I guess the offset is still pretty darn high. I am guessing that this can be adjusted with a spacer, but I bet it is always better to just find a wheel with a better offset.
Anyone having problems running spacers (+20)?
Old Aug 24, 2008 | 07:22 PM
Lawn Dart's Avatar
Lawn Dart
I'm running 18x10 +18 in the rear and it's perfectly flush. I think it might be okay, but if you got 20 mm spacers, that would help.
Old Aug 24, 2008 | 09:23 PM
joe645733's Avatar
joe645733
i have 19x10.5 +22. i can maybe fit 2 credit cards in between the rolled fenders and the tire. but make sure u get coilovers if you wanna go with somethin mean lookin
Old Aug 24, 2008 | 10:30 PM
terrasmak's Avatar
I run 18x10.5 +20 in the rear with proper sized tires and required a roll. If you dont want to roll +20 on the close side, to +30 will be just fine.
Old Aug 24, 2008 | 10:38 PM
jinsei888's Avatar
jinsei888
BAD offset? More like FAILed offset
Old Aug 25, 2008 | 12:42 AM
Goyangyi's Avatar
Goyangyi
I appreciate all the response. I think I will pass on this set of wheels and look for something that will fit correctly without a spacer. Thanks.
Old Aug 25, 2008 | 04:16 AM
Great to see members using a offset calculator. The wheels are 37 mm closer to the brake caliper than the OEM wheel. It is also 37 mm closer to the strut housing. Not good.
Old Aug 25, 2008 | 05:20 AM
terrasmak's Avatar
Actually its just fine and should clear , the wheel face is the factor involved with caliper clearance. My wheels without the 10mm spacer are 32mm closer without even coming close to rubbing anything.
Old Aug 27, 2008 | 08:47 PM
Faboo's Avatar
Faboo
yup
Old Aug 27, 2008 | 08:50 PM
mikez97's Avatar
mikez97
bad is too nice of a word for a +42 offset on a z
Old Aug 28, 2008 | 01:09 AM
Triple8Sol's Avatar
Triple8Sol
That's a horrible offset. Just pass on them.
Old Aug 28, 2008 | 02:06 PM
status:one's Avatar
status:one
Old Aug 28, 2008 | 02:18 PM
Marino Z's Avatar
Marino Z
Know it all
Originally Posted by status:one
LOL
Old Aug 28, 2008 | 10:21 PM
finalforce's Avatar
finalforce
Save your money and search for more aggressive wheels. Also make sure both front and rear are aggressive, I see a lot of people focusing too much on the rear that they ignore the front and the overall stance looks like a$$.
Justin100
Nov 25, 2021 06:26 AM
350z82
Oct 1, 2015 06:25 PM
