How does a 35 offset look? How do "Offsets" work?
Old Sep 13, 2008 | 10:41 AM
zcar03's Avatar
zcar03
Default How does a 35 offset look? How do "Offsets" work?
Thinking about a 19x9.5 wheels with a 35 offset. How would that look. Im not educated about offsets? How do they work. Thanks
Old Sep 13, 2008 | 10:49 AM
kelsey_kaye's Avatar
kelsey_kaye
find a lower offset.
Old Sep 13, 2008 | 11:04 AM
Motormouth's Avatar
Motormouth
if you search rim offset on google you can get an idea.
Concept
the simplest way to explain it is that the lower the positive (+) offset, the closer to the centerline of the rim barrel the hub(where the lug nuts are) mounts to the rim.
a zero offset would be the rim completely equal on each side of the hub. every stock car runs positive offset (the Z is +30 stock), which means the hub mounting point is farther towards the outside of the rim than the inside. As the offset lowers(+30,+25,+20, etc), the hub mounting point moves closer to the center of the rim barrel. when the hub starts being on the inside of the barrel centerline, that is negative offset and the number increases as it moves closer to the edge of the rim barrel (-5,-10,-15, etc); so the higher the positive or negative number, the more extreme the distance from the centerline.
Visualize
(the car is on the right hand side of the drawing, the '[' is the rim face, the '----' is the barrel of the rim)
zero offset (+0): hub mounts in the center of the rim
iii[
positive offset (+15): hub mounts on the outside of the centerline
ii[
negative offset (-15): hub mounts on the inside of the centerline
iiiiii[
the Z comes stock with a 18x8 +30 rim. you see where they sit. the higher the offset (+35 for example) the farther IN the rim will sit from the fender. offsets also matter with rim width (obviously).
Rim Width and How It Affects Actualized Offset
To compare different width rims with the same offset (to compare how they will look) I always added the MMs for the size difference like this, since rims are measured in inches, but offsets are in millimeters:
1 Inch = 25.4 Millimeters
So you divide 25.4 in half to get the offset difference (since offset is measured from the center) of a one inch rim width differene, which is: 12.7mm. Then you take that 12.7mm and add it or subtract it to whatever offset you have for the narrower/wider rim to see what a comparable offset would be (I round to 13mm for ease).
example:
18x8 +30 rim (stock) compares to a 18x9 +30 rim (Grand Touring stock rim size [F])
1 inch wider = the rim will sit 12.7mm farther out, so if you wanted the 8 inch rim to sit the same way the 9 inch does, you would need a +17 offset on the 8 inch rim.
*this is only to see how much farther OUT it will stick, inner fender clearance is not taken into account with this method.
Example of Fitment
A very standard rim fitment on the 350Z would be:
19x9.5 +22
19x10.5 +22
that sits fairly flush. most guys on this site run about a +20 offset. that will be semi-flush, not sticking out.
Summary
a +35 offset sucks, you will need spacers
Old Sep 13, 2008 | 11:06 AM
styles's Avatar
styles
I didn't know much about offsets either until motormouth thanks
Old Sep 13, 2008 | 11:24 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
dam motormouth. Lol good write up
Old Sep 13, 2008 | 12:57 PM
Old Sep 13, 2008 | 02:49 PM
carlili4190's Avatar
carlili4190
Originally Posted by davidv
you posted in 5 of those 7 threads shown...
and i bet they all had virtually same response
Old Sep 13, 2008 | 04:39 PM
Spike100's Avatar
Spike100
Motormouth,
Best explanation of offset I've seen that is understandable for anyone. Great job!
--Spike
Old Sep 14, 2008 | 03:44 PM
zcar03's Avatar
zcar03
Hey thanks alot very informative. So what would you say is the lowest offset that I can run with no rolling of fenders? Thanks I want them to be as far out. Or is +20 the min.
Old Sep 14, 2008 | 03:55 PM
jray8's Avatar
jray8
great info here!
Old Sep 15, 2008 | 05:52 AM
Motormouth's Avatar
Motormouth
depends on the wheel width.
Old Sep 15, 2008 | 06:09 AM
98Ekhatch's Avatar
98Ekhatch
more than likely like crap!!!!! un less you just like the way it looks...who cares what others think...and what he said it depends on the width.
Old Sep 15, 2008 | 06:23 AM
jubes's Avatar
jubes
Concept
the simplest way to explain it is that the lower the offset, the farther outboard from the centerline of the rim barrel the hub(where the lug nuts are) mounts to the rim.
Visualize
zero offset: hub mounts in the center of the rim
iii[
positive offset (+): hub mounts on the outside of the centerline
ii[
negative offset (-): hub mounts on the inside of the centerline
iiiiii[
S you divide 25.4 in half to get the offset difference (since offset is measured from the center) of a one inch rim width differene, which is: 12.7mm. Then you take that 12.7mm and add it or subtract it to whatever offset you have for the narrower/wider rim to see what a comparable offset would be (I round to 13mm for ease).
example:
Example of Fitment
19x9.5 +22
19x10.5 +22
Summary
best explanation of offsets I've read
Old Sep 15, 2008 | 07:21 AM
Peteski's Avatar
Peteski
Very nice explanation!!!
Old Sep 15, 2008 | 05:18 PM
sam2944's Avatar
sam2944
Default Offset on 18's
Concept
Visualize
iii[
ii[
iiiiii[
example:
Example of Fitment
19x9.5 +22
19x10.5 +22
Summary
Im planning to move to 18, my Z is 17. OEM wheels are 7.5" front and 8" rear. I will go with 8.5" front and 9.5" rear. Wheel manufactures suggest go with 20 offset. What do you think? I believe is a good offset due to I can make changes with spacers.......
Also for this wheel combo I also use mathematics, I think the ideal tires are 245/40 front and 265/40 rear. Tell me what you think, I like the tire a little out of the borders of the wheel, not entirely flush. Thanks
Old Sep 15, 2008 | 06:53 PM
Concave's Avatar
Concave
motormouth > davidv
Old Sep 15, 2008 | 07:53 PM
Spike100's Avatar
Spike100
That (what you say) will work. Consider 275/40-18 with 22 offset for your rears.
--Spike
Old Sep 15, 2008 | 08:23 PM
Originally Posted by Concave
motormouth > davidv
motormouth definitely gets the “nice guy” award.
Old Sep 15, 2008 | 08:33 PM
kno's Avatar
kno
motor mouth ftw this thread should be in the 100 z questions
Old Sep 15, 2008 | 08:34 PM
Spike100's Avatar
Spike100
Please forgive me if I misunderstand, but your statement sounds a little condescending.
In fact Motormouth provides the most understandable explanation of offset I’ve seen on this Forum. He took the time and effort to do a great contribution here, and I see that other members appreciate his effort.
--Spike
