safe/right psi for my 19" tires ???
Old Sep 16, 2008 | 09:54 PM
J_STATUS's Avatar
J_STATUS
Default safe/right psi for my 19" tires ???
here's the info:
Work Meister S1 3pc
19x9.5 (+19) front 19x11.0 (+17) rear
245/35 front 285/30 rear
now my main concern is how to protect my wheels in case of potholes, bump, or any kind of road imperfections that can bend my wheels....
what psi should i set it to? some people say run high psi around 38-40 psi so it can protect the lip of the rims....
THANKS GUYS!
Old Sep 16, 2008 | 10:05 PM
350ZTheStandard's Avatar
350ZTheStandard
What does the sidewall of the tire recommend for PSI???
Old Sep 16, 2008 | 10:14 PM
Nexx's Avatar
Nexx
car says 35 psi, i run 35 psi
Old Sep 16, 2008 | 10:41 PM
J_STATUS's Avatar
J_STATUS
i'll check the sidewall tomorrow but i think it says max psi is 44
Old Sep 17, 2008 | 06:48 AM
Z04's Avatar
Z04
1) open your driver door
2) look at the tire placard
3) inflate tires to that psi.
do not inflate to the psi on the tire. that is the max tire pressure and if you do that, not only will your ride be horrible, your tire may experience premature failure and/or cause you to wreck
i also suggest you take a course on basic auto mechanics.
Old Sep 17, 2008 | 07:17 AM
crg914's Avatar
crg914
+1
Old Sep 17, 2008 | 07:24 AM
You stretched a 245 mm tire on a 9.5 inch wheel, and you want to protect the wheel? Ha ha. Very funny.
Old Sep 17, 2008 | 07:54 AM
WTX350Z's Avatar
WTX350Z
35Psi is always a good starting point.
Old Sep 17, 2008 | 09:17 AM
DavesZ#3's Avatar
DavesZ#3
The sidewall pressure has nothing to do with the recommended tire pressure. That is the max pressure at max loading. It's usually significantly higher than the recommended pressure., The recommended pressure will give you a comfortable and safe ride, good wear and traction/performance.
Old Sep 17, 2008 | 09:36 AM
BigD2k5's Avatar
BigD2k5
10 psi over the max on the sidewall. post pics on outcome.
no srsly. go off the placard or you can hurt someone.
Old Sep 17, 2008 | 12:27 PM
fatboy.yoshi's Avatar
fatboy.yoshi
placard in your door jamb states...35psi...
Old Sep 17, 2008 | 04:57 PM
J_STATUS's Avatar
J_STATUS
im running 38 all around
Old Sep 17, 2008 | 05:04 PM
J_STATUS's Avatar
J_STATUS
yah i stretched 245 with 9.5 is that a very breaking news for you? people do it including me.... so if you're not gonna help you're gonna have to excuse my back....
J_STATUS >>>> <<<< DavidV
Old Sep 17, 2008 | 06:37 PM
Spike100's Avatar
Spike100
245mm width tire on a 9.5” wide wheel isn’t really much of a “stretch,” and is actually within recommended specifications for most tire manufacturers. It’s going to be slightly stretched, by not past normal.
I’m guessing when you ask about potential damage, you are worried about bending the wheel when hitting potholes, and scraping the wheel-rim with a stretched tire. I really don’t think you should worry about either of these, and instead focus on the proper inflation pressure.
For almost any tire you mount on your Z, you should use the recommended psi, which is 35-36 psi. If you mount a tire with a very soft sidewall, then experiment a little, and maybe use 37-38 psi. You should be aware that running a higher-than-recommended psi will result in uneven tire wear.
And, the pressures you use won’t have much to do with protecting against wheel-denting or rim-scraping. Certainly some wheels are better and dent less-easily, and some tires have rim-protector-ribs, but this has little to do with recommenced psi.
--Spike
Old Sep 17, 2008 | 06:57 PM
smellyborrelli's Avatar
smellyborrelli
im doing about 40 in the front and 36 out back with my 19s
Old Sep 17, 2008 | 07:07 PM
Voboy's Avatar
Voboy
35psi cold
38psi hot
... remember what it says on the sticker of the car is when the car hasn't been rolling around in the street for awhile.
Spike100's Avatar
Spike100
40 psi is high for the front. I would be concerned about uneven wear unless you have extra weighting in the front or a front tire that "needs" or "tolerates" more psi.
--Spike
Old Sep 17, 2008 | 07:19 PM
WTX350Z's Avatar
WTX350Z
--Spike
+43
Old Sep 17, 2008 | 11:52 PM
J_STATUS's Avatar
J_STATUS
--Spike
this is what i'm looking for....someone helpful......!!! yes my main concern is possibly bending my wheels (potholes) due to 30-35 series tires, so i would like to have the side wall to be as hard yet with safety psi to protect from bending the lip of the wheels.... thanks!!! so what do you suggest? i'm currently running 38psi front and back should i change it?
Old Sep 18, 2008 | 09:56 AM
BabyZiLLa's Avatar
BabyZiLLa
Maybe someone can explain why I called Toyo about these useless tires called T1R's. Worste sidewall flex in a Performance tire I've ever had.
They ask me what car. I tell them. They ask me my tire pressure. I tell them 36psi. He replies "There's the problem. With that tire you should be around 41-42psi"
I gave it a shot. Tire feels alot better. At 35-36psi the T1R's feel slippery and Flop over mid corner.
apex locator
Jul 23, 2021 02:27 AM
