Tire cutting
Old Sep 27, 2008 | 05:51 AM
mr04350zbase's Avatar
mr04350zbase
Default Tire cutting
Ok so my left rear tire kept going low. So I went to discount tire to see about getting it fixed, cause I could see a couple nails in it. Well they took it off and the inside of the tire was all torn up. The guy said that was fairly normal on 350z with wide tires. I have 275/35/18s on it. I was wondering is anyone else having that happen?
Old Sep 27, 2008 | 06:17 AM
DavesZ#3's Avatar
DavesZ#3
Anything is possible. Long nails near the sidewalls could easily rub on the inner surface of the tire causing it to tear.
I had a blowout years ago when a screw went through the outer treadblock of a tire. It was in there for a while and the threads of the screw started cutting through the sidewall due to the flex as the wheel rolled. It cut a 1" slit that blew out.
Old Sep 27, 2008 | 06:18 AM
350Zenophile's Avatar
350Zenophile
1. search: tire feathering
2. grab a thermos of coffee
3. read for days
Old Sep 27, 2008 | 06:40 AM
DavesZ#3's Avatar
DavesZ#3
3. read for days
I see what you're thinking, but if he is talking about the inner tread block being worn down, that's not the result of tire feathering. Feathering is an uneven wear. Worn inner tread block, especially on wide tires is usually caused by camber.
Maybe if OP posts back and clarifies "inside of the tire was all torn up", we can figure out which condition he's talking about.
Old Sep 27, 2008 | 07:28 AM
350Zenophile
True. He might be dumped and have massive negative camber as well.
Old Sep 27, 2008 | 07:37 AM
mr04350zbase
Well the tread of the tire was fairly even, but where the tread and sidewall meet is where it was cut up, the belts were even showing.
Old Sep 27, 2008 | 03:32 PM
68Stang's Avatar
68Stang
Is that a family photo? Which one are you?
Old Sep 27, 2008 | 04:29 PM
350zfun19's Avatar
350zfun19
so here is the right answer. that happens when you drive on flat tires or near flat. you have the weight of you car rolling on your sidewall of the tire causing it to flex (making it rub) and getting damaged and torn up. most shops call it run flat damage/ sidewall damage
Old Sep 28, 2008 | 06:18 AM
mr04350zbase
Well that sucks cause it is costing me a good amount of money. Oh well I should have paid more attention to it, that and passing cars at 145mph on the way to work had to help tear it up.
Old Sep 28, 2008 | 07:22 AM
350Zenophile
I think we have a future Darwin award winner here. I hope you realize how close to death you were. You have no sense, common or otherwise.
Old Sep 29, 2008 | 08:26 AM
mr04350zbase
lol What can I say, I don't care about safety just fun.
Old Sep 29, 2008 | 07:13 PM
350zfun19's Avatar
350zfun19
thats a selfish thing to say im sure your family would care if you were dead or not...
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
