spacer question
Old Sep 30, 2008 | 02:27 PM
avandss's Avatar
avandss
Default spacer question
i have the oem 07-08 wheels, i am planing on getting the 25m spacers for the rear, but since im dropped with gf210's can i put on 265 in the rear with my 25m spacer and drop?
that would be the perfect setup for stock wheels if it fits!!!
Old Sep 30, 2008 | 03:49 PM
I don't know. Put the tire on the wheel and the wheel on the car. Do you have 25 mm clearance? If yes get some spacers.
Old Sep 30, 2008 | 07:54 PM
350zDex's Avatar
350zDex
IM GETTIN 07 WHEELS FOR MY 05 IM DROPPED ON TEIN S TECH'S I PLAN ON DOING THE SAME SET-UP BUT WITH EITHER A 255 TIRE OR 275 KEEP POSTED IF U DO IT!!
Old Sep 30, 2008 | 08:09 PM
tight350z's Avatar
tight350z
i have a 25 mm on the rear.. with gf210s and a stock sized tire...and i would say NO...im almost rubbing...i have barely a finger clearance between my wheel and the fender...idk how close it is when i hit a bump..
Old Oct 1, 2008 | 03:07 AM
terrasmak's Avatar
275 doesn't fit the 07 wheels, 265/40 is the widest you can go.
If it rubs just roll the fender, to get the nice and flush look a roll is always needed.
Old Oct 1, 2008 | 07:30 AM
tight350z's Avatar
tight350z
as i said im running spacers on a gf210 drop.. go ahead and prepare to buy a camber kit as well...do it right atleast...anyway, i have 25mm in the rear and 20mm in the front...i would think 25mm in the front would be too much...IMO.. anyway, heres with stock sized tires...
>>>>>PICS>>>> http://www.new.facebook.com/album.ph...cd&id=78202050 <<<< PICS<<<<<
Old Oct 1, 2008 | 12:07 PM
trodis's Avatar
trodis
I just put on 25 in the rear and was thinking of 25 in front. How flush is it with 20 on the front? Does it match well with the rear?
Old Oct 1, 2008 | 01:09 PM
tight350z's Avatar
tight350z
20 up front is perfect.. Just flush.. 25 would make it look funny bc the front would be out farther than the rears.. You won't be upset with 20 bc it's just flush.. But as always it's ur car!
Old Oct 1, 2008 | 01:34 PM
kelsey_kaye's Avatar
kelsey_kaye
i have 25's all around. the fronts do look a bit more flush than the rears, but then again i'm not dropped at all. i'm glad i didn't go with the 20mm.
Old Oct 1, 2008 | 01:38 PM
kelsey_kaye
Old Oct 1, 2008 | 04:11 PM
tight350z's Avatar
tight350z
well heres my side profile..and im lowered....
Old Oct 1, 2008 | 07:37 PM
z-u-later's Avatar
z-u-later
I've got 25mm in front & 30mm in rear, and they're flushed.
Old Oct 1, 2008 | 07:38 PM
z-u-later's Avatar
z-u-later
You need to lower that Z, Kelsey!
Old Oct 1, 2008 | 07:46 PM
kelsey_kaye
tell me about it. but i don't want to go the cheap route with just springs. so i'm saving for coilovers and camber settings.. the works.
Old Oct 1, 2008 | 07:49 PM
350zDex's Avatar
350zDex
MAN UR CAR LOOKS SICK IM GETTIN MY 07 WHEELS TOMORROW BUT IM JUST GO WITH 25540R18 IN REAR AND 245 OR 235 UP FRONT IM LOWERED ON TEIN S-TECHS AND WILL POST PICS WHEN MOUNTED ON CAR WITHOUT SPACERS THEN WIITH!!
Old Oct 2, 2008 | 04:48 AM
z-u-later's Avatar
z-u-later
Okay, I guess I'll let you slide . . . for now.
The Z definitely looks much better lowered with flushed rims.
Old Oct 2, 2008 | 05:56 AM
trodis's Avatar
trodis
Thanks for the pics everyone, I think I am gonna go with 20 on the front, due to the fact that I am lowered. Tight350z, I am hoping it comes out looking like yours.
Old Oct 2, 2008 | 09:33 AM
kelsey_kaye
true statement.. and trodis what are you gonna run on the rears?
Old Oct 2, 2008 | 09:59 AM
tight350z's Avatar
tight350z
i think once you lower the car with spacers you will notice a complete difference...but i would def. go ahead and buy the spc front and rear arms... they have a deal goin for i think $525? thats what i paid for front and rear!
Old Oct 2, 2008 | 10:55 AM
kelsey_kaye
the z should've came from the factory with better offsets. even with my car at stock height it looks 100x better with the spacers. plus +1. the car will look wayyy better with a drop and spacers.
