30mm wheel spacer PIC request
Old Oct 18, 2008 | 06:20 AM
Toby-22's Avatar
Toby-22
Default 30mm wheel spacer PIC request
Hi everyone, I have an 03 track Z with the track rays. Im currently running 20mm/25mm wheel spacers on stock suspension. Right now it looks pretty flushed with the fenders, but after I lower it by an 1" im sure it wont look so flushed. Plus i want my wheels to stick out a bit more from what i have now. Is anyone here running 30mm in the rears? I want to move the 25mm to the front and put in 30mm in the rears. Im also gonna be putting 255/45 for the front and 265/45 for the rear to get a more aggressive look. If anyone have any pics of this setup, I would really appreciate it.
Thanks!
Old Oct 18, 2008 | 04:38 PM
Done Deal DR's Avatar
Done Deal DR
It just depends on your offset...We would need to know what the offset on your wheels is to provide you with pictures of wheels that stick out X.XX MM. The space size itself doesn't actually matter.
Old Oct 19, 2008 | 08:50 AM
Toby-22's Avatar
Toby-22
8" wide +30 offset front and 8.5" +33 rear
So no one here is running with 30mm spacers? I don't really care whether the wheels are track wheels or just regular stockers. I just want to see what the 30mm would look on stock wheels. I searched but nothing? Thanks!
Old Oct 19, 2008 | 09:51 AM
My350P's Avatar
My350P
Can't say I've ever even seen 30mm ones for sale, 25mm is the largest I've seen.
Old Oct 19, 2008 | 10:25 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
you defenetly dont want to go too big on spacers, they will only cause problems later.
Old Oct 19, 2008 | 10:27 AM
z-u-later's Avatar
z-u-later
Hey, I received your PM requesting pics of my setup. I run 25mm in front & 30mm in rear. The stock rims, to include the track OEM rims, are perfectly flush. I've ran this setup on autocross & road courses without issues. I'll see if I can post some pics.
Old Oct 19, 2008 | 10:57 AM
Toby-22's Avatar
Toby-22
Originally Posted by z-u-later
Hey, I received your PM requesting pics of my seutp. I run 25mm in front & 30mm in rear. The stock rims, to include the track OEM rims, are perfectly flush. I've ran this setup on autocross & road courses without issues. I'll see if I can post some pics.
Thanks man, yea if you can post some pics it would help me out a lot!
Old Oct 19, 2008 | 05:30 PM
sam2944's Avatar
sam2944
Need to know actual offset to make a proper opinion/suggestion. Let me know......
Old Oct 21, 2008 | 06:28 AM
z-u-later's Avatar
z-u-later
He already stated on his original post the (implied) offsets by saying he has the OEM track rims.
Old Nov 19, 2008 | 01:21 PM
p0tential's Avatar
p0tential
post pics! post pics! post pics!.....
i have an 03 track as well and have 25mm on the back that i also want to move to the front and get 30mm on the back!!
Old Nov 23, 2008 | 01:53 PM
nick123's Avatar
nick123
a 30 ,, spacer and a 265 tire will be rubbing ...You will need to roll the fender...I have 25 mm spacers on teh rear and a 265 tire and lowered 1 inch on eibach pro kit....
Old Nov 23, 2008 | 03:50 PM
z-u-later's Avatar
z-u-later
If it's the correct offset, it will not rub. I had a track setup with 275/40 tires mounted on 17x9 rims with +35mm offset. And I'm lowered ~2". No rubbing at all even though my rear fenders are rolled.
I still owe you guys pictures of my setup with 25mm front & 30mm rear spacers on stock '06 rims/tires. I'll try to get some pictures this week and upload them. Just need to wash my car first.
Old Nov 24, 2008 | 05:31 AM
Toby-22's Avatar
Toby-22
Hey man, so you were lowered 2" with 30mm spacers and no rubbing? Im running 25mm in the back and plan to change it to 30mm with 265/35 tires on my oem rays. Im lowered about 1.5" with fenders rolled, you think ill rub?
Thanks!
Old Nov 24, 2008 | 10:52 AM
z-u-later's Avatar
z-u-later
Thanks!
No, it shouldn't rub. I still have my stock 245/45 rear tires in the back and it doesn't rub with the 30mm spacers. I also had a track setup with 275/40 tires with the 30mm spacers and it did not rub. The 265/35s are shorter in diameter compared to the two sets of tires I mentioned.
Obadabot
Jun 18, 2023 11:31 PM
